rebuilt trans still slips NEED HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2012, 06:48 PM   #1
chevy_4x4_trucks
chevy_4x4_trucks's Avatar
Default rebuilt trans still slips NEED HELP
Alright guys heres my problem. I had my trans completely overhauled because the trans was slipping going into 3rd. Well i put it back together and it still slips going into 3rd and now.doesnt shift into 4th at all. So what the hell could be causing this. Both my dad and myself are stumped and i want to figure tbis out before it snows seeing this is my plow truck any input would help thanks....also this is a 4l60e in a 2003 silverado
chevy_4x4_trucks is offline   Reply With Quote
Old October 13th, 2012, 07:45 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
who did the rebuild? fluid full? sounds like they didn't even fix it
Old October 13th, 2012, 07:48 PM   #3
chevy_4x4_trucks
My dad is the one that rebuilt the trans. He is did it at the dealership where he works He has rebuilt them for me before and never had a problem. And yea the fluid is full
Old October 13th, 2012, 07:51 PM   #4
chevy_4x4_trucks
when i first put it in i broke one of the wires going to the trans plug and it didnt have 1st or 4th. It only had 2nd and 3rd and when it shifted to third then it shifted fine now that i have first gear it slips going into 3rd and still doesn't have 4th....could it be a weak pump and not getting enough pressure to operate now that i have 1st again
Old October 13th, 2012, 07:53 PM   #5
Little Dave
Little Dave's Avatar
Take it back to Dad and ask?
Little Dave is offline   Reply With Quote
Old October 13th, 2012, 07:57 PM   #6
chevy_4x4_trucks
Im trying to hold off on pulling it back out if i can...kinda hoping it to be something in the valve body ir sensor of some kind...i was kinda thinking maybe its a weak pump or something...also i noticed that when i really step on it ( not quite wide open) it doesnt shift outta 1st till almost redline but shifts fine into 2nd
Old October 13th, 2012, 08:20 PM   #7
MilwaukeeF350
Dan
Sound like electric issue. Happened to me on 2 trucks.
They act like neutral rev to 6K rpm and not ever moving until you stop and restart then it drove fine for while. Turn out bad rear sensor speed on axle was short out.
Time to do OHM all wires find which one is rot or bad contact.
Old October 23rd, 2012, 02:44 AM   #8
xjagain
03' is that fly by wire or does it still have a shift cable?
If your sensors ohm out, and it is fbw you should be able to get a shift solenoid fire sequence and test the solenoids to make sure they are firing in the correct order, at the correct time. Or your dad should be able to hook it to a Motis or possibly a Tech 2 at the dealership and run a diagnostic on the trans.
xjagain is offline   Reply With Quote
Page generated in 0.44835 seconds with 47 queries
