Beaterk5's sas project - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2012, 12:33 AM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default Beaterk5's sas project
Well I just picked this up. It's a 96 Tahoe it has air bags on all 4 corners. The entire susp needs re worked so I'm going to throw it up on some leafs for now. later down the road if I keep it maybe a link'd susp front and rear.
Right now what's planed is ord spring hanger kit and 8" springs up front. Out back I'm thinking a shackle flip with an add a leaf and a 4" block. After the susp and steering are done ill move on to putting a motor in it. Luckily the p.o didn't cut any wires when he pulled it so I can drop in another Vortec motor and run the 4l60e trans and push button t-case. For gears I'm planing 456's with 6 lug outers on a 44 and a sf 14 bolt rear, with a 37-39" tire.
What'cha all think?
And some pics
beaterk5 is offline   Reply With Quote
Old October 13th, 2012, 10:52 PM   #2
beaterk5
beaterk5's Avatar
Found my front axle today it's not a high pinion but it'll work. Was sitting in a truck out back that had Been forgot about. Also picked up some not destroyed or missing front hangers spring's, shackes and shackle mounts.
Old October 13th, 2012, 11:05 PM   #3
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Wow, I'm glad you are redoing the suspension....that is some scary fab work!
Kyle M. is online now   Reply With Quote
Old October 14th, 2012, 12:45 AM   #4
beaterk5
beaterk5's Avatar
Yes, yes it is...... The angles are for articulation right?
Old October 14th, 2012, 02:51 AM   #5
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
that thing could be pretty cool....glad your redoing the "suspension" lol.
That needs to go into the booty fab thread lol
Old October 14th, 2012, 03:10 AM   #6
beaterk5
beaterk5's Avatar
Lol ya I'm aiming for the same height just a completely different suspension lol. It's aprox 10" of height gain right now I'm going for 11-12" in the front and about 10 in the rear. The best part will be i can take every one wheeling. plus you don't see very many tahoes lifted much less solid axle swaped
Old October 14th, 2012, 03:13 AM   #7
beaterk5
beaterk5's Avatar
Check out my " 2 link mount" I mean swing arm
And just for kicks my fleet including the 84 if this one goes well I may do the blue 94 too just a lil smaller though
Old October 14th, 2012, 08:07 AM   #8
Dirthog250r
FORD POWER!!!!!!!!!!!!!!!
Dirthog250r's Avatar
Good to.see a tahoe lifted im work on giting my 97 up some
Dirthog250r is offline   Reply With Quote
Old October 16th, 2012, 06:55 AM   #9
beaterk5
beaterk5's Avatar
You going solid axle, ifs or body lift? Me and 95yukongt are going to use this one as a learning curve and do his 95 2 door after mine
Old October 17th, 2012, 05:58 AM   #10
beaterk5
beaterk5's Avatar
Well not going to make any progress this week in parts gathering bought this with my Tahoe money instead for the week
http://www.marlinfirearms.com/firear...re/1895SBL.asp
Old October 19th, 2012, 03:26 PM   #11
Dirthog250r
Im just going with ifs just so i can fit a 33 to 35 still want it as my tow rig but still do light wheeling nice gun lol
Old October 19th, 2012, 09:43 PM   #12
beaterk5
beaterk5's Avatar
Sounds like what my 94 has. a 3" body and 35's. and thanks on the gun ive wanted it for a bit of time now.
also have some bad news on the Tahoe.Its frames out by about 1-1/2" so it's getting parted out.so time to tear apart a perfectly good truck that just needs a rear end
97 Chevy z71 Vortec 350, true duals with flows, hypertech, k&n filter, trick flow t.b. spacer. hopefully by spring ill have a 6 lug sas with a 77 ford 44 and factory 10 bolt may try and find a sf 14 for it but that can always be changed later.
Already have the front axle a set of 6 lug outers, ord shackle flip and 6.5" super shackle are on there way. going to also put in a 4" block and ord 0 rate add a leaf to net 10" of lift rear. Front is yet to come but going to be ord sas kit, 8" 73-87 front spring. Along with the ord cross over steering set up an a ried racing/ dedinbear flat top knuckle. After that all that will be left will be to figure out shock length and mounting, and figure out length for a set of 81-87 ext brake lines. since I will be using calipers from that year truck should be a blot on and go there. Hopeing to be out of this for under 3000 including truck purchase price. Minus wheels tires and gears i feel it should be very do-able.
The truck
Old October 31st, 2012, 07:22 PM   #13
beaterk5
beaterk5's Avatar
Got my rear parts in off road design shackle flip and 6.5" super shackles.
Page generated in 0.31509 seconds with 62 queries
