Tsls in the front Boggers in the rear..who's doing it and u like it?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2012, 02:59 PM   #1
bigredjeep1
Default Tsls in the front Boggers in the rear..who's doing it and u like it??
Tsl in the front Boggers in the rear..who's doing it and u like it??
I have 39.5x18x15 Boggers on allied beadlocks and 39x15x15 TSLs on steel non beadlock rims. Not sure on the difference in rim width at the moment but could this combo work? Both in the width of the tire and having non beadlock front rims on the TSLs and beadlocks on the rear Boggers?
I wheel in the Midwest and it seems to be a combo alot of guys use for rock and also the mud boggers too!
How common would you say it is to do the TSL front / Boggers rear combo?
Best of both worlds for mud/rock/lateral stability/drivetrain longevity?
I have only wheeled at the Badlands in Attica, IN but I know that Boggers are the king of the mud but with rocks thrown in probably good to do the TSL/Bogger combo!
When I lived in northern California I loved my 37x12.5x15 GY MTRS on my built XJ and many people ran those tires for the Rubicon and other rock crawling trails there although the TSL SX tires I have seen too and are very tough!
bigredjeep1 is offline   Reply With Quote
Old October 12th, 2012, 03:30 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
great combo
H.o.r.e
Old October 16th, 2012, 11:25 AM   #3
bigredjeep1
It sounds like it is the best of both worlds and lots of positive responses regarding it on my Pirate4x4.com thread. Thought I would get more responses here in the Midwest based website!
http://www.pirate4x4.com/forum/gener...ng-u-like.html
Old October 16th, 2012, 12:08 PM   #4
92FleXj
stacks stacked on stacks
92FleXj's Avatar
i always herd people did this because tsls get less traction in mud and are less likely to put a hurting on your front driveline. not sure how true that is but it is a common setup.
and i second the stl sx! my next tires will be sxs or pb rockers
Old October 16th, 2012, 12:55 PM   #5
Around here, yeah, that was pretty common. While everyone has alloys and dana 60s these days, there weren't always good options. Lots of people ran 38-44s in Jeeps and broncos on front dana 44s. You were limited with 30 spline outers, stock hubs, etc. So it was common to run a LSD instead of a locker, and less aggressive TSLs in the front.
I ran SSRs front/boggers rear in my CJ5, which was a nice combo for running mud and anything that needed floatation.
I don't like boggers for trail use thats going to see a lot of off camber, they walk sideways way too much.
By far, my favorite all around tire is a swamper SX, with cut treads (in the pattern that I've posted here before). I've run them like this in 36 and 38.5 sizes on beadlocks usually around 4-7 psi, and they are very good for the terrain around here.
Old October 25th, 2012, 10:05 AM   #6
bigredjeep1
How do you like the SXs siped? Cut middle V shaped lugs in 1/2 or thirds and cut larger lugs on ourside down the middle?
Cut bogger big lugs in 3rds and smaller lugs in 1/2? In V shape cuts 3/4" deep and 1/4 wide?
I see a tire siper for $70 I'm thinking of getting from a post I saw on here or Pirate.
Page generated in 0.32163 seconds with 41 queries
