TJ: how do i remove tj Tcase linkage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 12th, 2012, 06:00 AM   #1
sluginxlt
tooweel or not tooweel
sluginxlt's Avatar
Default how do i remove tj Tcase linkage
I'm in the middle of pulling my trans/transfercase and was trying to figure out the easiest way to dissconect Tcase linkage for manual trans removal
sluginxlt is offline   Reply With Quote
Old October 12th, 2012, 07:30 AM   #2
Wramblerguy
Wramblerguy's Avatar
Pry the metal linkage out of the plastic grommet and then move you whole teams passenger side to slide to pivot piece out of the hole on the body
3rd generation jeeper
Old October 12th, 2012, 01:31 PM   #3
sluginxlt
sluginxlt's Avatar
Not sure what you mean whole teams passenger side to side?
Old October 12th, 2012, 01:36 PM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Whole t-case to the side
H.o.r.e
Old October 12th, 2012, 02:08 PM   #5
Doesn't the drivers side piece come out with removing 4 bolts under the carpet? I thought you removed that part, then the linkage could come out. But its been 10+ years since I messed with it.
Old October 12th, 2012, 02:22 PM   #6
kickstand
circling the drain
kickstand's Avatar
there are 4 bolts that hold the shifter to the body, the linkage pops out with a small prybar
Page generated in 0.18291 seconds with 41 queries
