First Start on old engine with new gaskets - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 11th, 2012, 12:00 PM   #1
amc78cj7
amc78cj7's Avatar
Default First Start on old engine with new gaskets
History:
Bought this early bronco 4 years ago. Removed the 302. Replaced the oil pump and shaft. Replaced the seals and gaskets.
During the past 4 years it has sat, unstarted, as we built a new bronco around it. We're now at a point where we can start it up.
Is there anything I should do, other than just turn the key, considering it's been sitting 4 years without running?
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old October 11th, 2012, 01:15 PM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
Drain the oil and replace before starting, every ounce is in the pan, and four years worth of moisture from condensation.
Maybe prime the oil pump first for good pre-lube.
Did you double check to make sure it still turns freely.
Old October 11th, 2012, 01:18 PM   #3
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
prime the oil pump.disable the ignition and roll the engine over a few times with the starter.
hawkscj5 is offline   Reply With Quote
Old October 11th, 2012, 07:14 PM   #4
I suck cocks. Lots of them.
locally famous
i would roll it over by hand, maybe with plugs out, mice and creatures hide stuff in cylinders
Old October 13th, 2012, 03:34 PM   #5
frdboy
frdboy's Avatar
As stated above, fresh oil and filter. If it is an older 302 with a flat-tappet cam I would also run a break-in/zinc additive. I would pull the dist. and pre-lube it. Don't crank the motor a bunch before starting it, the cam, lifters and piston pins are splash-lubed and I would imagine most the oil has run off them. Get it started and get some RPM in it for 10mins or so, 1800-2500 varied.
Old October 13th, 2012, 05:54 PM   #6
firehawk
Live Action!
firehawk's Avatar
x2
Could also spray some fogging oil in the cylinders, better to do it before storage but could still help.
Page generated in 0.32647 seconds with 41 queries
