2/1 ratio - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 11th, 2012, 08:54 PM   #21
Thats the thing. IF you want it interesting, do something interesting. If you want it fast, do something fast. Don't try to mix.
FYI, if you want a turbo, the shift times and HUGE gear splits in the sm465 will drop you out of boost and power band with every shift.
Old October 11th, 2012, 10:05 PM   #22
Nuggets
I fix stuff!
Nuggets's Avatar
The fail runs deep in this thread. I'm outa here.
Old October 12th, 2012, 06:27 AM   #23
my head hurts...........
Old October 12th, 2012, 06:33 AM   #24
kickstand
circling the drain
kickstand's Avatar
This guy even makes hag gar look less retarded
Old October 12th, 2012, 06:53 AM   #25
Old October 12th, 2012, 08:15 AM   #26
Sandals
Fucking Zen as Shit
Sandals's Avatar
Dude, you over think everything to the point of not even a good idea.
Old October 12th, 2012, 08:28 AM   #27
joe_jeep
welfare wheeler
joe_jeep's Avatar
the .52 to one is useless under 100 mph. you will not be able to use it. an overdrive that tall sucks. ask anyone with a 42re about tall overdive ratios. i would do anything to have a .75 or .8 od instead of my .67. the rpm drop in hig gear blows. it has no power. cant hold speed even on flat ground with a head wind. i get your ideas. they are just way too high in the upper ratios. its a waste.
Old October 12th, 2012, 09:33 AM   #28
Like most of your posts, I am trying to offer reasonable advice, as hard as it is sometimes.
Why not go a little more old school. lowered 40s pickup, 4BT diesel, and your big crash box transmissions. Seems a lot more your style. You seem to have an obsession with the lowest cruise RPM possible. Why not build something that actually likes low rpm?
Old October 12th, 2012, 10:58 AM   #29
cerial
Direct Drive FTW
cerial's Avatar
I am using a lt1 t56 in the s10. Been done, works, the 465 in the s10"was stupid.
I am using the 465 in the buggy because I do like old school iron drivetrains. The "high" range in the brownie is just for highway and will rarly be actually used unless I decide to put 5.88 gears in later. Make a bit more sence now?
I plan on leaving the brownie in 1/1 most of the time. The reverse case which is really 2 spur gears meshing on 2 shafts will give a .75/1 reduction which will give aceleration of a 80's truck. If I wanted fast I would have built a rail.
Old October 17th, 2012, 04:32 PM   #30
Wramblerguy
Wramblerguy's Avatar
ive got 2 sets of 2.73 dana 44 gears/carriers ill make u a deal on
3rd generation jeeper
Page generated in 0.25489 seconds with 53 queries
