TJ: 2001 Grand Caravan injectors in 2001 TJ 4.0? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 10th, 2012, 07:36 PM   #1
Paintballpsyco236
Paintballpsyco236's Avatar
Send a message via AIM to Paintballpsyco236 Send a message via MSN to Paintballpsyco236 Send a message via Yahoo to Paintballpsyco236
Default 2001 Grand Caravan injectors in 2001 TJ 4.0?
Per the title, can I do that? The Grand Caravan is a sport model with the Flex Fuel 3.3L V6 engine. I know all about the Neon thing so need to bring that up, have a chance to get these dirt cheap to possibly free but can't seem to find any info on the donor injectors. Anyone happen to have any insight on this at all? Thanks for any help all,
Paint
Paintballpsyco236 is offline   Reply With Quote
Old October 12th, 2012, 02:31 AM   #2
Paintballpsyco236
Anybody? Need to figure this out in the next couple of days here or the Dodge is getting scrapped...
Paint
Old October 12th, 2012, 09:33 AM   #3
Toivo
Feel lucky?
Toivo's Avatar
Compare flow rates, impedence values, wiring connector and fuel rail Ports yourself. You have all the damn parts. want the info, get off your azz and look it up. You know what parts, make, and models you are dealing with, make an effort.
Old October 12th, 2012, 10:49 AM   #4
bdd1469
bdd
bdd1469's Avatar
^^ like he said+ what are you trying to acomplish? What is wrong with the jeep injectors?
Old October 13th, 2012, 03:32 AM   #5
Paintballpsyco236
I tried, spent about 4 hours trying to find ANY info on these injectors and did it about two days in a row, all I came up with was 4 different part numbers which lead back to the sites I go them from. Can't find any flow rate info, or any "stats" of any kind. It is an EV6 connector, and will plug into the TJ fuel rail no doubt. The injector plug is just a bit lower on the body than a Dodge Neon injector that is compatible with my model, and they are green, not black. I have done as much research as I can right now, hence me posting here for help. If I had found the info, I would not have needed to post here for help. I am capable of making a compatibility judgement on something like this provided I can find the data to compare to the other data I have for potential matches. That is why I posted here asking for HELP.
Originally Posted by bdd1469 View Post
^^ like he said+ what are you trying to accomplish? What is wrong with the jeep injectors?
I am simply trying to accomplish a cheap (being that I can probably get these for free) upgrade to my TJ. These injectors are the 4 hole injectors like the Neon ones, and an EV6 connector, and the recess for a clip to fit directly into my Tj fuel rail. Seemingly a direct fit. If you are familiar with the reasons for doing the Neon injector upgrade, I am trying to see if I can apply it to the set I can probably get for free from something similar. The problem being that I can't find ANY info on these damn things anywhere! (see my above response for more details). There isn't anything wrong at all with the stock injectors, I just want the power and performance gains of an upgraded injector. If I can do that for free, why not? lol. But I can't find the info myself, such is the reason I posted here hoping that someone may have considered this, or may have come across some info pertaining to this idea, or at least have an idea or suggestion of where to look. Needless to say, thus far I have come up dry and may miss out on this opportunity now...
Paint
Old October 13th, 2012, 04:01 AM   #6
curbdog17
Mini Van
curbdog17's Avatar
Originally Posted by Paintballpsyco236 View Post
I am simply trying to accomplish a cheap (being that I can probably get these for free) upgrade to my TJ.,
Then just try it. You will have way less time into seeing if it works than you already spent in failed research.
Old October 14th, 2012, 07:01 AM   #7
RADRICK
RADRICK's Avatar
check jeepforum.com there is a big post on what works.
Page generated in 0.33508 seconds with 44 queries
