Currie nine housing 35 spline axles disc brakes rear - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 9th, 2012, 09:39 PM   #1
Rubilooe
Rubilooe's Avatar
Default Currie nine housing 35 spline axles disc brakes rear
Currie hd rear housing nine inch tj width 35 spline axles disc brakes
Never installed or assembled currie nine inch hd housing was built for a tj the upper control arm and shock mounts have been removed ,the lower control arm brackets and coil spring pads are still intact . One pair of 35 spline axle shafts with bearings and all that have never been installed and a complete currie rear disc brake set up complete with e brake cables and backing plates again never installed so all is new . The axles are studded for 5 on 5.5 bolt pattern.just going a different way with my latest build.
No third member included
269-858-5620
750.00
located in constantine michigan.
KDN KUSTOMS
Rubilooe is offline   Reply With Quote
Page generated in 0.17234 seconds with 26 queries
