TJ: Clutch exploded - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 8th, 2012, 11:44 PM   #1
joe&jeep
WHISKEY-TANGO-FOXTROT
joe&jeep's Avatar
Default Clutch exploded
I have an '05 TJ, 4.0 6 speed and my clutch exploded, what would cause this. It also took out the slave cylinder.
joe&jeep is offline   Reply With Quote
Old October 9th, 2012, 06:52 AM   #2
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I've done it drag racing. Not in a jeep though. Faulty clutch disc I'd say if you weren't beating on it.
Old October 9th, 2012, 07:29 AM   #3
joe&jeep
joe&jeep's Avatar
No beating on it, daily driver, dealer had tranny out and kind of thinking maybe misaligned during reinstall.
Old October 9th, 2012, 08:56 AM   #4
frdboy
frdboy's Avatar
How/when did it happen, accel./decel?
Old October 9th, 2012, 09:59 AM   #5
joe&jeep
joe&jeep's Avatar
don't know when it happened, didn't hear anything unusual just didn't have any pedal pressure and no clutch, was shifting from 3rd to fourth when felt nothing
Old October 9th, 2012, 10:05 AM   #6
Dylan
Dylan's Avatar
wait? so you were just driving and went to shift from 3rd to 4th (assuming you still had power and forward motion to get up to speeds to be able to go to 4th) and then when you went to shift you had no clutch? This is what I read. This is NOT a exploded clutch. Whoever told you that is blowing smoke up your A.
An exploded clutch will loos all forward power, send the motor into high rpm like you through it in neutral and be VERY loud.
Sounds like a clutch slave or master to me. Put it in N and start the engine. If it sound like its going to blow up, then clutch is bad. If its perfectly quiet, than clutch is ok. Put it in 1st and start it if its quite in N. If it goes (take the N safety off obviously) and has plenty of torque, clutch is good and its something else in there.
Old October 9th, 2012, 10:14 AM   #7
joe&jeep
joe&jeep's Avatar
dealer has tore it apart and looks as if clutch plates have shredded, going by pics they sent me
Old October 9th, 2012, 10:22 AM   #8
frdboy
frdboy's Avatar
Were they driving it when it happened? About the only way i have see a disc come apart was with to much input shaft RPM like if you went into 1st at to high of road speed.
Old October 9th, 2012, 10:26 AM   #9
joe&jeep
joe&jeep's Avatar
I was driving it on my way to work
Old October 9th, 2012, 10:31 AM   #10
joe&jeep
joe&jeep's Avatar
I was told by one of the guys at work(we are Maintenance in a factory) who has been a mechanic for 20 years before this job, that it sounds and looks as if it was put back together and misaligned, and just trying to get some other ideas, I have drove nothing but manual transmissions for over thirty years and have never experienced anything like this, let alone have a clutch problem
Old October 9th, 2012, 10:56 AM   #11
Rob the plumber
Once the dealer has it apart you're at their mercy. They can tell you what they want, and generally hide what they don't want you to know. Cover their ass basically.
Like said earlier, if the clutch disc exploded, it would make a shit ton of noise and would not be drivable.
Old October 9th, 2012, 11:25 AM   #12
deerebowtie
Unchained
deerebowtie's Avatar
how much does a stealership charge to do a clutch disc replacement?
Old October 9th, 2012, 11:35 AM   #13
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
you cant put it together if its misalligned, it physically wont go together.
Old October 9th, 2012, 11:45 AM   #14
joe&jeep
joe&jeep's Avatar
so far right now, slave cylinder, clutch , and flywheel machining $1500+
Old October 9th, 2012, 11:51 AM   #15
Rob the plumber
Holy fawk I'm glad I can turn a wrench!
Pure speculation, but maybe the pressure plate bolts were overtorqued and sheared off, causing disaster?
Old October 9th, 2012, 12:00 PM   #16
deerebowtie
Unchained
is their hourly rate like 3-400? I'm in the wrong field apparently....
Old October 9th, 2012, 12:01 PM   #17
Sandals
Fucking Zen as Shit
Sandals's Avatar
Ouch
Old October 9th, 2012, 12:11 PM   #18
hosejockey4506
Visiting Admin
holy good lord.
Old October 9th, 2012, 12:12 PM   #19
hosejockey4506
Visiting Admin
slave cylinder 65 bucks
clutch 140
machine 50
so 255 in parts 1250 labor ?????????????????????
Old October 9th, 2012, 12:24 PM   #20
joe&jeep
joe&jeep's Avatar
Stealership
Page generated in 0.45329 seconds with 83 queries
