wj Rear axel seal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2012, 10:43 PM   #1
rkperry1
Jeeper
rkperry1's Avatar
Default wj Rear axel seal
So I have a jeep grand cherokee 2001 and my rear driver side axel keeps leaking fluid. Ive had the seal replaced no joke like 3 or 4 times since ive had it. (4 years). each time I have to pull the shaft and have it sent in to be machine pressed a new seal on. then it leaks a few months or so later? what is going on?? Please help! Is my housing bad? or my axel shafts grooved or something making my seals go bad. Ive also had to do the other side prolly 2 times.
Might be in the market for some shafts.
Thanks for your time
rkperry1 is offline   Reply With Quote
Old October 7th, 2012, 11:01 PM   #2
14muddn
yes
Old October 7th, 2012, 11:10 PM   #3
rkperry1
Jeeper
rkperry1's Avatar
Yes? LOL to what my housing or my shafts being bad? Shafts are like 300 to 500 each at o reillys. junk yard?
Old October 8th, 2012, 01:03 AM   #4
89Laredo
89Laredo's Avatar
Send a message via Yahoo to 89Laredo
(dont post tech questions in the pub.)
All I want to do is smoke meth, fuck my sister, and hang myself with a belt.
89Laredo is offline   Reply With Quote
Old October 8th, 2012, 01:08 AM   #5
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Talking
This may help...
http://www.greatlakes4x4.com/showthr...&highlight=psa
Old October 8th, 2012, 09:20 PM   #6
rkperry1
Jeeper
rkperry1's Avatar
Wish I could get a real answer... my axle is leaking down my tire
Old October 8th, 2012, 09:22 PM   #7
boggin-machine
boggin-machine's Avatar
pretty sure they had aluminum rear axles and bend easy. not sure what years had what but tha could be it.
Old October 8th, 2012, 11:50 PM   #8
rkperry1
Jeeper
rkperry1's Avatar
ive notcied that when i have my rear end in the air with the tires off if i put it in drive the caliper moves in and out meaning the shaft isnt straight
Old October 9th, 2012, 11:53 AM   #9
Wramblerguy
Wramblerguy's Avatar
not all wjs have the dana 44a with the aluminum center section it depends on your motor
if its a v8 it has the 44a but if it has a 4.0L then its just a regular dana 35
it sounds like a grooved axle to me if its the dana 35 i think they are the same axles and any other dana 35 so you should be able to find a set realy easy for less then $100
3rd generation jeeper
Old October 10th, 2012, 10:54 AM   #10
88yjproject
I second the grooved axle shaft. Didn't some of the dana 35's come with the c-clips on the axle shafts instead of the bolt on plates? I did mine not too long ago and I put a little rtv around the outside of the seal where it slides into the housing. But I would say you have a grooved axle or maybe there is a small bur or something causing the seal to go bad that quick.
88yjproject is offline   Reply With Quote
Old October 10th, 2012, 03:22 PM   #11
Wramblerguy
only the early dana 35s were semi-float (non c-clip) like 88 and earlier i believe
Page generated in 0.28077 seconds with 56 queries
