YJ steering damper bolt broke off. Also have bad death wobble. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 6th, 2012, 02:44 PM   #1
Daniel
SFA Ranger
Daniel's Avatar
Default YJ steering damper bolt broke off. Also have bad death wobble.
The axle under the front of my truck is out of a 94 Jeep YJ.
I've had a slight shake around 45-60 and it got worse so I checked everything.
The only thing I could see wrong was the steering damper, it was leaking a little.
As I was removing the bolt from the axle side, it broke, taking my hand with it and breaking my middle finger.
Anyways, I'm looking for the replacement bolt (or the size/thread).
I'm also looking for someone that might be able to drill it out or remove it somehow.
The shake has now turned in to the full blown death wobble from hell and I can't drive over 40mph.
ID:	97378   Click image for larger version
Daniel is offline   Reply With Quote
Old October 6th, 2012, 05:27 PM   #2
Wehan
Wehan's Avatar
Try balancing your tires and go from there. The damper is just a band aide for a bigger problem.
Wehan is offline   Reply With Quote
Old October 6th, 2012, 05:28 PM   #3
Daniel
SFA Ranger
Daniel's Avatar
I've taken it to belletire twice, I even had them rotate the tires again.
Old October 6th, 2012, 07:10 PM   #4
Daniel
SFA Ranger
Daniel's Avatar
The death wobble seems to start after I hit a bump that compresses the suspension.
I've checked everything except the bolts for the leaf springs, they look like they haven't moved, stupid rust.
I haven't checked the axle joint on the passenger side, my friend said it could cause the death wobble but it still looks fine. No rust/powder around the seals.
He said it could also be the carrier bearings, but wouldn't that cause even more problems?
I need to find someone that can get the bolt out for me, I don't have the tools to drill and tap it.
Old October 6th, 2012, 10:03 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
a axle joint wont cause death wobble
the carrier bearings wont cause death wobble
i would check ball joints , tie rod,wheel bearings 1st
H.o.r.e
Old October 6th, 2012, 10:08 PM   #6
Daniel
SFA Ranger
Daniel's Avatar
I'm about to say f this thing and push it in to a lake.
Old October 14th, 2012, 09:11 AM   #7
Daniel
SFA Ranger
Daniel's Avatar
I'm still looking for someone in the Livonia/Westland area that can drill/tap this for me.
Page generated in 0.30137 seconds with 45 queries
