what kind of axles am i looking at? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2012, 09:47 PM   #1
dfm_13
dfm_13's Avatar
Default what kind of axles am i looking at?
guy thinks they are out of a 78 chevy, what side drop is that front im having a hard time telling cause im kinda dumb.
dfm_13 is offline   Reply With Quote
Old October 4th, 2012, 09:48 PM   #2
dfm_13
dfm_13's Avatar
never mind, its passenger drop, for some reason the pics are alot bigger on here than on CL. but is the rear a 14 bolt?
Old October 4th, 2012, 09:50 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
Passenger
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 4th, 2012, 09:58 PM   #4
dfm_13
dfm_13's Avatar
while we are at it, i found this one too guy says its out of a 70 bronco. that would make it a 44 correct. is 70 a decent year to put into a jeep....sorry im new
Old October 4th, 2012, 09:59 PM   #5
dfm_13
dfm_13's Avatar
and what knuckles if any can i use on this to convert it to 8 lug like the rear axle posted above. sorry im just trying to see if i wanna buy these
Old October 4th, 2012, 10:27 PM   #6
skife
skife's Avatar
don't pay much for them, the front is a half ton chevy axle 10bolt or 44 (i don't remember) and the rear is just a 14b (i think) they made about a billion of each of them.
Old October 4th, 2012, 10:37 PM   #7
dfm_13
dfm_13's Avatar
guy wants 50 for both. but im thinking about keeping my 8.25 our back and picking up the bronco 44 because they are similar width (right?) and i found a build where a guy used one on his cherokee and just lengthened the radius arms and the think flexed great for him.
like so...
Old October 4th, 2012, 11:02 PM   #8
dfm_13
dfm_13's Avatar
scrap that its a d30 not 44
Old October 4th, 2012, 11:20 PM   #9
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
I was gonna answer but you beat me to it. The closed knuckle drum front cannot be made into 8 lug for any reasonable amount of money, unless you do all of the machining yourself. The Chevy front end could be made into an 8 lug with bolt on parts, to match the rear end, and you would get the benefit of full width, plus the strength of 3/4 ton axles.
zook94 is offline   Reply With Quote
Old October 4th, 2012, 11:27 PM   #10
dfm_13
dfm_13's Avatar
only issue is the chevy is passenger drop though.
any idea what these may be out of? im thinking ford because they are 5 lug?
http://up.craigslist.org/cto/3188628088.html
Old October 5th, 2012, 04:59 AM   #11
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
You need to give more info about what you are trying to build and then you can get some educated answers about what axles you should get.
Old October 5th, 2012, 05:02 AM   #12
chadcooper55
I'm taking a guess that you are building a Cherokee? If so leave the Dana 30 up front and get an 8.8 out of an explorer for the rear. Same bolt pattern and width and you can get them with disks, 4:10 gears and a limited slip. That combo will get you up to 35" tires depending on how you are with the skinny pedal.
Old October 6th, 2012, 12:23 AM   #13
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
If you want an early bronco dana 44 you want a 1977. That will be the narrow width with disc brakes. Be carefull because a 1977 F150 Dana 44 is a full width high pinion axle. That last link you posted is for Dodge axles, Dana 44 up front and 9.25 rear. Drivers drop, but not very desirable because they are Low pinion and have the Vaccum disconnect in the tube.
Old October 6th, 2012, 02:15 AM   #14
dfm_13
dfm_13's Avatar
Gotcha well thanks for the help guys, I have done so much reading on what axles you want and don't want but still feel like I know nothing lol
Old October 6th, 2012, 06:22 AM   #15
chadcooper55
Well then post up what you have and what you are planning to do and I'm sure everybody can get you steered in the right direction.
Page generated in 0.28372 seconds with 68 queries
