(2) OBA air tanks (from CJ-10a tug) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2006, 07:21 PM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default (2) OBA air tanks (from CJ-10a tug)
I have two (2) air tanks that were pulled from one of my CJ-10a tugs. $20 each, or $35 for both along with an air governor, air valve & pressure guage.
Located just west of Grand Rapids.
Thanks,
Craig
1x1_Speed_Craig is offline
Old October 22nd, 2006, 07:41 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Rough idea of the size, 2 gal? I probably take one or both.
Thanks Adam
Jeepaholic is offline
Old October 22nd, 2006, 07:49 PM   #3
drummond
MTU 4x4
drummond's Avatar
hey craig, any idea on the dimensions of them? does that hose connect to the pump? its hard for me to tell in the picture ( at least on this computer). Ill probably take one. Thanks
drummond is offline
Old October 22nd, 2006, 08:01 PM   #4
1x1_Speed_Craig
Simplify...
Hey guys,
The tanks each measure 6 3/4" diameter by 14" length.
The lines were cut for removal. However, I have the complete CJ-10a manual with detailed diagrams on the complete OBA setup. The compressor pump connected to the air governor assembly. I can get you copies of the diagrams if you want.
Thanks,
Craig
Old October 22nd, 2006, 08:04 PM   #5
drummond
MTU 4x4
drummond's Avatar
so the air connected into the flexible lines....or into the part that is coming off the side of the tank?
drummond is offline
Old October 22nd, 2006, 08:26 PM   #6
Jeepaholic
Jeepaholic's Avatar
I will take one, sending a PM.
Old October 22nd, 2006, 08:36 PM   #7
1x1_Speed_Craig
Simplify...
OK, from the manual (in order of the flow of air)...
Air compressor (supply) --> alcohol evaporator --> Left-hand air tank...
Left-hand air tank
(1) --> Air governor --> Air compressor (return)
(2) --> Right-hand air tank -->
(a) Gladhand coupling (rear)
(b) Drain valve/heater
(c) Gladhand coupling (front)
(d) T-fitting...
T-fitting -->
(1) Air valve --> T-fitting --> Front & rear gladhand couplings
(2) Pressure guage
Keep in mind that this vehicle has 2 gladhand couplings on the front, and 2 on the rear. It was designed to run commercial air-powered equipment. A basic OBA setup will differ significantly. I just figured someone could use some inexpensive tanks to assist with a low-buck OBA project.
Craig
BTW, here's the in-cab control/pressure guage:
Old October 23rd, 2006, 06:08 AM   #8
1x1_Speed_Craig
Simplify...
One sold (99grandtj)...one left. Did you want it, Brent?
Craig
Old October 23rd, 2006, 07:46 AM   #9
Squeak
Send a message via AIM to Squeak Send a message via Yahoo to Squeak
do you have any long runs over 5 ft of hose and fittings i would take those
Squeak is offline
Old October 23rd, 2006, 08:02 AM   #10
1x1_Speed_Craig
Simplify...
Hi Rob,
I'm sure some of the runs are over 5', and some of the lines are still in the vehicle. Let me wait until the 2nd tank is sold, and we'll go from there (I want to give the buyer(s) first option at the extra parts).
Craig
Old October 23rd, 2006, 09:38 AM   #11
itselliott
itselliott's Avatar
Craig,
Consider the second one sold.
PM sent
Harry
itselliott is offline
Old October 23rd, 2006, 09:58 AM   #12
1x1_Speed_Craig
Simplify...
Originally Posted by itselliott View Post
Craig,
PM sent
Harry
It's yours, Harry. BTW, I found that other set of black CJ bumperettes. How does $10 for the set sound?
Rob - I'll take a look at the air lines/fittings I have. Check back with me at the end of this week.
BOTH air tanks are now SOLD.
Thanks,
Craig
Page generated in 0.22561 seconds with 59 queries
