Engine ticking - even after shutdown - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 3rd, 2012, 07:42 PM   #21
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
I don't think I have any detonation either. If I remember correctly, my quench is right about 40 thou, and I think they are Sealed Power 677P pistons with a 17.5cc dish.
Looking through my old notes, I am pretty sure these are the valve springs I am running...
http://www.summitracing.com/parts/DCC-5249464/
These should be the lifters that I am running.
http://www.summitracing.com/parts/DCC-4529220/
Blue XJ is offline   Reply With Quote
Old October 3rd, 2012, 07:54 PM   #22
Sfa_Colorado
RIDGEOFFROAD.COM
Sfa_Colorado's Avatar
Well we can't say what the reason really was there are a lot of things that could have happen and with out pulling it a part we can't tell you for sure what it is making the noise
RIDGEOFFROAD.COM•RIDGE RUNNERS OFFROAD•355NATION.NET
"THE MORE I LEARN ABOUT WOMEN, THE MORE I LOVE MY TRUCK"
Sfa_Colorado is offline   Reply With Quote
Old October 3rd, 2012, 07:57 PM   #23
Sfa_Colorado
RIDGEOFFROAD.COM
Chad also said:
In the past I have been very happy with the equivalent of a 30 cc dish between milling the reliefs and decking the block ... My guess Is you have too loose tolerance on the installed height... Or you have a spring or two that has failed ...
Old October 3rd, 2012, 08:01 PM   #24
Blue XJ
The Green Machine
Blue XJ's Avatar
By a spring failing, does that mean it is broken? Or it's just lost some of its 'spring'? When the motor was off, I was touching each of the rocker arms and could feel the ones that were making the noise, I had 3 of them that I could feel move when I heard the tick, the other ones didn't budge. Maybe its worth replacing those 3 springs to see what it gets me.
Old October 3rd, 2012, 08:07 PM   #25
GREASYHANDS
GREASYHANDS's Avatar
Sounds like the expansion & contraction of the exhaust when you shut it down. The loose rockers may not have the cam lobes trying to open them.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 3rd, 2012, 08:11 PM   #26
Sfa_Colorado
RIDGEOFFROAD.COM
Could be broken or loss of tension... If you find it has lost tension ... Double check coil bind numbers and make sure it is able to deal with the rocker arm ratio and cam you are running...
Old October 5th, 2012, 12:30 AM   #27
Sfa_Colorado
RIDGEOFFROAD.COM
You get it figured out?
Old October 7th, 2012, 06:23 PM   #28
Blue XJ
The Green Machine
Blue XJ's Avatar
I'm getting another set of valve springs to try from a guy at work, along with the compressor to remove them with the head on the vehicle. Until then, I've moved on to other projects. Thanks for the help. I'll check back in when I get the new parts.
Old October 22nd, 2012, 11:14 AM   #29
Blue XJ
The Green Machine
Blue XJ's Avatar
Well, I finally got around to swapping out the valve springs. The noise is gone.
Page generated in 0.36930 seconds with 50 queries
