TJ: LS2 Swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 2nd, 2012, 01:13 AM   #1
Dannn
Dannn's Avatar
Default LS2 Swap
Planning an LS2 Swap, 4l70E w/ AA np231 adapter. Ford 8.8 rear with 4.10 gears, on 35's
Front will be a stock d30 left alone until i pick up an axle worth swapping in.
Question: Is the 8.8 gonna hold up to 400hp and 35's? No mud, no rocks, just sand and trails. Rather easy on the skinny pedal, however i'd like to be able to use the power when i need it.
Also, anyone know what year chevys came with a 231c case that will bolt up to a newer style 4l60e? or even what years came with an np241c that will bolt up? 27 spline output 6 bolt pattern on the trans. any tcase ideas that i can just bolt up and run instead of swapping in a jeep case? i can deal with the jeep speedo later on, have some ideas on that one other than the factory speed sensor.
Dannn is offline   Reply With Quote
Old October 2nd, 2012, 01:28 AM   #2
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Any type of locker?
Old October 2nd, 2012, 02:00 AM   #3
Dannn
Dannn's Avatar
thinking a full case eventually in the 8.8
do the full case lockers help with strength? or put more strain on shafts?
Old October 2nd, 2012, 06:01 AM   #4
If only sand and trails, you will be fine.
Old October 2nd, 2012, 10:09 AM   #5
Dannn
Dannn's Avatar
Okay thanks for the help. Anyone know of any adapter ideas?
Page generated in 0.22878 seconds with 38 queries
