Utility Locators - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 30th, 2012, 11:57 AM   #1
Tdanks76
Tdanks76's Avatar
Default Utility Locators
I'm trying to find someone to locate an underground electric line from my house to the garage. Miss Dig won't do it because it's a "private line" after the meter. How am I suppose to go about this?
I'm located in Grand Rapids, MI.
Tdanks76 is offline   Reply With Quote
Old September 30th, 2012, 12:07 PM   #2
jimhri
jimhri's Avatar
contact a local electrical supply house and ask them. the longer they have been in business the more likely they've fielded this issue before.
jimhri is offline   Reply With Quote
Old September 30th, 2012, 12:09 PM   #3
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Around here there is a company called Underground Technologies Inc. (UTI) They are who Ms. Dig uses instead of having their own lackies. You might wanna google underground locating services and see what you can find.
zook94 is offline   Reply With Quote
Old September 30th, 2012, 12:16 PM   #4
yupjeep
If u were close I could do it for u
yupjeep is offline   Reply With Quote
Old September 30th, 2012, 12:19 PM   #5
jimhri
jimhri's Avatar
how? is there a special meter or something?
Old September 30th, 2012, 12:21 PM   #6
yupjeep
Rd8000 radio read locator I can locate it and even find a bad spot in your line
Old September 30th, 2012, 12:24 PM   #7
jimhri
jimhri's Avatar
can u rent one of these or do you have to hire someone?
Old September 30th, 2012, 12:27 PM   #8
yupjeep
[QUOTE=jimhri;3173204]can u rent one of these or do you have to hire someone?[/QUOTEim not sure if you can rent them or not
Old September 30th, 2012, 12:29 PM   #9
jimhri
jimhri's Avatar
thx
over and out
Old September 30th, 2012, 12:43 PM   #10
Bo's Cj 7
Bo's Cj 7's Avatar
We use this company for work all the time but not sure on cost.
http://www.terraprobeenvironmental.com/
Bo's Cj 7 is offline   Reply With Quote
Old October 1st, 2012, 04:54 PM   #11
Gunsworth
Gunsworth's Avatar
you can rent them, chet's has them i know and they might have a location near you. they have a couple near me. wanna say they are like 60$ to rent
Old October 1st, 2012, 06:36 PM   #12
Tdanks76
Tdanks76's Avatar
Hopefully I can find one to rent. Keep this going, it would be great if someone could do this on the side for me.
Old October 2nd, 2012, 09:27 PM   #13
FyrFyr
FyrFyr's Avatar
Lakeland Electric out of GR can do this for you. They do a bunch of work at my employer and do good work. Should just take a few minutes.
FyrFyr is offline   Reply With Quote
Old October 2nd, 2012, 11:52 PM   #14
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Call miss dig. Tell them you are putting in underground sprinkling. They will ask who's the contractor, tell them you're doing it yourself. They will ask if there are any areas of specific concern. Tell them the northeast corner or what ever corner of the house your barn is on. Don't tell them anything about the private wire that's post meter. I called them yesterday, they were out this afternoon.
Old October 3rd, 2012, 04:57 AM   #15
jthomp
jthomp's Avatar
You can always witchy stick it. If the other locators use metal flags pull one up and put a 90* bend in it for a handle. Walk slowly across the area and be amazed.
(disclaimer) if you can't make the witchy stick work it's a sign of homosexual tendencies
jthomp is offline   Reply With Quote
Old October 3rd, 2012, 06:16 AM   #16
Smiley
Smiley's Avatar
Originally Posted by jthomp View Post
You. An always witchy stick it.
I've done this in the past, mostly for sewer and water lines. I use two brass coat hangers bent into an L shape with them held in each hand. Walk perpendicular over what you want to find. They will cross each other over the line.
Be aware that you will also get tree roots, so cross the suspected line path in multiple places along the route.
I'm in Byron Center, send me a PM.
Smiley is offline   Reply With Quote
Old October 3rd, 2012, 07:47 AM   #17
kickstand
circling the drain
kickstand's Avatar
I watched the old dude who inspected my septic do that witchy stick thing, I was amazed. never tried it myself.
Old October 3rd, 2012, 08:21 AM   #18
clarkstoncracker
lol
clarkstoncracker's Avatar
I have the equipment if you have a chaser wire.
All underground gas lines or electric lines should include a 16THHN or equivalent to use as a pulse wire.
If you don't have a chaser wire, if you can disconnect the wire (not sure what it is feeding), you can pulse it and locate it.
Old October 3rd, 2012, 01:11 PM   #19
Chinski
You guys are a little confused about miss-dig. Their people do not do the locating nor do they set up a contractor to do it. Miss-dig just looks up what utility companies are in that general area and they notify them that you will be digging. It is each utilities responsibility to either send out one of their people or get a contract service to do it. So the utility is only going to locate their own lines. There isn’t just one guy who comes out and finds every buried line regardless of who owns it.
United Rental has them. I'm sure other places do too. http://www.ur.com/index.php/equipmen...ab=description
Chinski is offline   Reply With Quote
Old October 3rd, 2012, 03:22 PM   #20
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
All I know is Monday I called Miss Dig. Tuesday I was out there until 2pm. I swung back around 630, and Gas, cable and telephone had been marked. Something tells me it was 1 person that came out, not 3.
Page generated in 0.40455 seconds with 82 queries
