Thread Tools
Old September 26th, 2012, 09:27 PM   #1
Zach4739
2005 Willys
Zach4739's Avatar
14 bolt axle shaft swap, 8 lug to 6 lug
i have a 14 bolt out of a heavy half (2500) 6 lug. i want to take another 14 bolt out of anything else with 3.73s i figure its gona be out of a 2500 8 lug. could i take the 6 lug shafts and replace the 8 lug shafts? would it be that easy?
-DONT TELL ME TO UPGRADE THE FRONT TO 8 LUG, its going in a 1500 tahoe the axle was free and the old one is trash so i figured to go big.
Zach4739 is online now   Reply With Quote
Old September 27th, 2012, 06:43 AM   #2
kickstand
sHaMoNe!
kickstand's Avatar
Not likely. If I recall the 6 lugs were semi float and the 8 lugs are full float. Axle shafts should be different.
I am not 100% sure on this, there may be an oddball full float 6 lug out there, but none that I am aware of.
Old September 27th, 2012, 09:18 AM   #3
Zach4739
2005 Willys
Zach4739's Avatar
thanks for the comment i think i might just through another 10 bolt in it
Old September 27th, 2012, 09:24 AM   #4
deerebowtie
Unchained
deerebowtie's Avatar
the heavy half would be a 9.5" semi-float 14 bolt. staying with the 9.5", axle shafts will swap...the 10.5" full-float is a different axle all together. Hit up youtube for a diy video to make sure you have the process down pat before you start.
Old September 27th, 2012, 10:15 AM   #5
Complete Off Road
Axles - Driveline Parts
Complete Off Road's Avatar
The GM 9.5 (what some refer to as the semi-float 14 bolt) uses 33 spline C-clip shafts.
The GM14T (the full floater Corporate 14 Bolt) is 30 spline in stock form.
There is nothing similar between the two axles other than they share the same number of cover bolts.
Buy with confidence from
The #1 Authorized Dealer of Yukon Gear and Axle Off Road Products
563-583-5363
Andy@CompleteOffroad.com
Use code "GL4X4" at checkout for 5% off SSC branded products at CompleteOffroad.com
FREE SHIPPING ON ORDERS OVER $199*
Yukon, USA Standard, ARB, Warn, Currie, Bubba Rope, Master Pull, Trail Defense, and more
Authorized Yukon Dealer since 1998
Like us on Facebook!
*Free Shipping to USA on most items. Excludes all EATON products and oversized or heavy items. Excludes wholesale orders.
Complete Off Road is offline   Reply With Quote
Old September 27th, 2012, 04:23 PM   #6
sandman101
What's wrong with the 9.5" 6 lug? Different gearing than front diff?
sandman101 is offline   Reply With Quote
Old September 28th, 2012, 02:53 PM   #7
Zach4739
2005 Willys
Zach4739's Avatar
yes wrong gear and when i took it apart i saw the spider gears are chewed up a bit
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.09559 seconds with 24 queries
