Chevy Blazer bad idle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2012, 09:24 PM   #1
BuckinBronco
BuckinBronco's Avatar
Default Chevy Blazer bad idle
Posting for a friend of mine...
2001 Chevy Blazer
4.3L auto
Decent idle in park but when shifted drops off and stalls or catches itself and rpm shoots up around 1500
New parts:
Fan Clutch
Radiator
Idle air control valve
Throttle position sensor
Air check valve
Throwing out codes of p0418, p0134, p1133 and p0463
BuckinBronco is offline   Reply With Quote
Old September 26th, 2012, 10:21 PM   #2
davidkassie
davidkassie's Avatar
Codes are probably a different issue.. 418 is secondary air injection, usually not a running issue. 134 and 1133 are drivers side upstream 02 sensor.. could cause a running problem, not usually your symptom. And 463 is fuel level sensor issue . Sounds like u have a major vacuum leak.. good luck
davidkassie is offline   Reply With Quote
Old September 29th, 2012, 06:07 AM   #3
RADRICK
RADRICK's Avatar
How does the brake pedal feel, any vac boost? EGR valve will stick open and cause rough idle & no power brakes.
Old February 13th, 2013, 01:23 AM   #4
xNMTBx
xNMTBx's Avatar
My 98 spits and sputters as soon as I hit the gas... I'm lost
xNMTBx is offline   Reply With Quote
Page generated in 0.19165 seconds with 35 queries
