XJ: crossmember stud removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2012, 07:28 PM   #1
special k
special k's Avatar
Exclamation crossmember stud removal
i've tried everything i can think of to get the studs out of my xj body for the x member. i tried using two nuts as a jam nut to try and thread them out, heat and vice grips, and welding a nut to the stud, all attempts failed so far. does anyone else have any ideas besides drilling, or any easier ways of extraction??
Old September 25th, 2012, 07:46 PM   #2
davidkassie
davidkassie's Avatar
Add a step to your technique.. heat cherry red, and cool as quickly as possible..water hose, etc. This has worked numerous times. Weld a nut on it first if u can.. even use an air chisel lightly to vibrate threads on bolt.. just a thought. Good luck.
davidkassie is offline   Reply With Quote
Old September 26th, 2012, 05:43 AM   #3
kmanxj5011
kmanxj5011's Avatar
You used heat as in a oxy acetylene torch? or a propane torch?
Welding a nut on and heating it with even a proprane torch and then spraying aerokroil on them alway got them out for me.
kmanxj5011 is offline   Reply With Quote
Old September 26th, 2012, 06:15 PM   #4
special k
special k's Avatar
Used map gas, had it cherry red too
Page generated in 0.19385 seconds with 35 queries
