Tcase Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2012, 06:21 AM   #1
nd4spd71
nd4spd71's Avatar
Default Tcase Question
Will a tcase out of a 2000 TJ with an 4.0/Auto work in a '97 xj with a 4.0/auto?
nd4spd71 is offline   Reply With Quote
Old September 25th, 2012, 06:42 AM   #2
curbdog17
Mini Van
curbdog17's Avatar
I believe they are clocked differently. but should still work.
Old September 25th, 2012, 07:32 AM   #3
Dylan
Dylan's Avatar
the clocking is in the trans not the t-case. It will bolt right in. I can't remember if they are both the long input shaft but I believe they are.
Old September 25th, 2012, 09:53 AM   #4
nd4spd71
nd4spd71's Avatar
Thanks for the info guys.
Old September 25th, 2012, 11:35 AM   #5
Denny's price seems great Gary Worst case you can swap the input from your current T-case into it if they turn out to be different.
Old September 25th, 2012, 01:22 PM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Input is longer on the tj but you can swap it or cut it down
Page generated in 0.25286 seconds with 41 queries
