TJ: Swaybar Link Problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 23rd, 2012, 10:27 AM   #1
DZWrangler
DZWrangler's Avatar
Default Swaybar Link Problems
I installed new front links on my tj and the nut is just spinning with the threaded piece. Is there any tricks to make it not spin. I tried using a pair on vicegrips but it can only grab to a certain point.
DZWrangler is offline   Reply With Quote
Old September 23rd, 2012, 11:01 AM   #2
jbsjunk
Little Member
jbsjunk's Avatar
A pry bar from the frame to the sway bar pushing the taper together tight should do it as long as you're using OE type of links. You are talking about on the bar, not the diff end yes?
Old September 23rd, 2012, 11:09 AM   #3
beedle4
beedle4's Avatar
Moog and some other brands have wrench flats on the back side. Or use an impact to spin it quicker than the stud.
Old September 23rd, 2012, 02:04 PM   #4
DZWrangler
DZWrangler's Avatar
Thank you jbsjunk i got it using the prybar idea
Page generated in 0.50313 seconds with 35 queries
