Alternator HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2012, 02:39 PM   #1
Spudy
Redneck Excavator
Spudy's Avatar
Default Alternator HELP
Hey guys
I have a 94 jeep grand cherokee with the 5.2. it has a externally regulated denso alternator 90 amp on it (5300 8647). Called a junk yard to get a bigger one as i have converted to an electric fan and have a winch and they said they had one (told them i wanted one that was out of a 98 zj with the 5.9) Got home with it and did not look at it and is NOT out of a zj. It looks to be out of a dodge 99 and newer and is internally regulated. (denso 56028 920ab)
Question is there an easy way to convert this internally regulated regulator to work on my external wired system?
Thanks.
Spudy is offline   Reply With Quote
Old September 22nd, 2012, 02:55 PM   #2
92FleXj
stacks stacked on stacks
92FleXj's Avatar
What's the amp of the new one? I put a 100 amp on my Xj which I was told was a "direct bolt in but would be tight" and I can tell you it was not... It took a lot of grinding to get it to fit.
Old September 22nd, 2012, 03:00 PM   #3
Spudy
Redneck Excavator
Spudy's Avatar
the new one is a 136 amp. and im sure it will bolt in as many have done it but the damned salvage yard got too new of one so it will not bolt right in :-(
Old September 22nd, 2012, 03:05 PM   #4
Jeep ZJ
Jeep ZJ's Avatar
if its from a 99 dodge then it should still work.
Old September 22nd, 2012, 03:16 PM   #5
Spudy
Redneck Excavator
Spudy's Avatar
well it is different. i went by this link
V8 ZJ/Durango 5.9L alternator upgrade - NAXJA Forums -::- North American XJ Association
post number 6. mine is like the first pic and the new one is like the second.
Page generated in 0.25455 seconds with 39 queries
