4.0 stalls - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2012, 11:55 AM   #1
yyj87
yyj87's Avatar
Default 4.0 stalls
4.0 - ax15-231j 1991 wrangler
When using the engine as a brake for more than 2-3 seconds or reving the engine past 2500 rpm and letting off the throtle it dies. This is a slow death, 3-6 seconds of sputtering at 300 rpm then stall out. Starts right up and idles/runs fine.
Iac,tps,o2, crank sensor and map are new in the last 6 months for other reasons.
Fuel pressure steady at 45 psi.
No codes thrown aside from ac
Looking for sugestions.
yyj87 is offline   Reply With Quote
Old September 20th, 2012, 12:29 PM   #2
jerm97xj
I fixed it!!!
jerm97xj's Avatar
I dont know if it works on jeeps but GMT 800 trucks need the throttle body cleaned for a stalling issue. Its worth a shot.
jerm97xj is offline   Reply With Quote
Old September 20th, 2012, 04:31 PM   #3
yyj87
yyj87's Avatar
When i did the iac i cleaned it with a dremel a whire wheel/cone. This issue was present before tb clean and didnt change.
Thankyou but i dont think thats it, i will inspect the tb again for shits&gigles tonight.
Page generated in 0.43068 seconds with 32 queries
