Plastic injection molding help (mold changes) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 19th, 2012, 03:15 PM   #1
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Default Plastic injection molding help (mold changes)
Here is my issue: Prior to a mold being pulled all the air, hydraulic and water lines need to be unhooked to remove the tool. When that happens all the water that is left in the lines and in the tool spills all over the floor and the machine. Currently we try and mop it all up, but that still leaves a slippery mess for dust and dirt to stick to and also a slip hazard. So does anyone have any ideas or do something now to prevent the mess? Is there a way to plug all the fittings until I get it back to the tool room where it can be drained out??
Old September 19th, 2012, 03:19 PM   #2
xj4life
xj4life's Avatar
ball valves just before lines enter/exit the tool.
Old September 19th, 2012, 03:20 PM   #3
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
^ This, or solenoid water valves...
RIP FULLSIZE4LIFE
Old September 19th, 2012, 03:22 PM   #4
deerebowtie
Unchained
deerebowtie's Avatar
let me google that for you
Old September 19th, 2012, 03:41 PM   #5
Immortal
NO RELIGION WAT!
Immortal's Avatar
Seriously? I would fire you for making the mess.
Old September 19th, 2012, 03:51 PM   #6
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
SlayerXJ is offline   Reply With Quote
Old September 19th, 2012, 04:01 PM   #7
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Put high pressure quick release fittings on in the lines/molds.
Look here
Old September 19th, 2012, 04:06 PM   #8
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Look here
X2 for sure
Old September 19th, 2012, 04:46 PM   #9
GearDrive
A little slow
GearDrive's Avatar
There is not a lot of room for solenoids or valves. A valved quick connect will restrict flow.
I design molds for Chris, so come up with something easy.
GearDrive is offline   Reply With Quote
Old September 19th, 2012, 05:17 PM   #10
RyeBread
Catch the wave
RyeBread's Avatar
couldn't you just leave a 12" section of the above hoses with a ball valve dangling from each that has a quick/connect fitting to the main hoses?
that way the tool, with all of the 12" sections can be transported to a properly drained/clean room where the die/mold/tool can be drained, and those 12" hoses with the quick release fittings applied to the new/dry tool/die/mold?
Old September 19th, 2012, 05:18 PM   #11
Can you fit in an air fitting somewhere in the system before the mold, to blow any remaining water back into the system before disconnecting?
How frequently do you need to disconnect the lines?
Old September 19th, 2012, 05:35 PM   #12
deerebowtie
Unchained
you can oversize your couplings to not reduce flow.
Old September 19th, 2012, 05:41 PM   #13
Mr.Green
I can levitate!
Mr.Green's Avatar
There are many solutions. How much can you spend on the fix?
Old September 19th, 2012, 05:43 PM   #14
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
??? A valved quick connect doesn't seem to reduce the flow in our AmKus (jaws of life), and that is one that place a reduced flow is life and death... Or as previously mentioned, over sized quick connects.
Old September 19th, 2012, 06:07 PM   #15
cameron69
dog farts are the worst!!
cameron69's Avatar
Pm catman he can hep you with the quick disconnects.
cameron69 is offline   Reply With Quote
Old September 19th, 2012, 07:18 PM   #16
ppkaprince98
Size Matters (.)(.)
Yes, we could but I think Geardrive just added those as a possible solution, we typically dont build molds that way. We normally have one large in and one out to reduce time making the water connections like you can see in his drawing towards the top left side of the mold. Geardrive can correct me if I mispsoke.
Haggar, the water comes in and out of the mold via a temperature control unit and circulates the water at a certain temp, so we cannot blow anything backwards into the system. We unhook the temp controllers and loop them so water can circulate and wont burn up the pumps.
We unhook the lines at every mold change which is anywhere from 5 to 15 mold changes a day between 26 machines.
I am open to all options, I dont have an endless budget, but I will pay for a solution that works.
Old September 19th, 2012, 07:20 PM   #17
GearDrive
A little slow
GearDrive's Avatar
That's the difference between pressure and volume. Imagine a valved coupler on your fire hose. The pressure will go up and the volume will go down. You rely on the volume of water to put out the fire.
Old September 19th, 2012, 07:38 PM   #18
cerial
Direct Drive FTW
cerial's Avatar
Why won't ball valves work?
They will close off the flow preventing (most) of the water from escaping while still letting the water recirculate and maintain temp. You will loose the water from the ball valve to the fitting. But, as far as simple, cheap, and effective a ball valve that can handle the proper pressure in the lines seems like a easy fix.
Just make sure all the ball valves are open after hooking up the fittings before beginning a new part.
Old September 19th, 2012, 07:45 PM   #19
Mr.Green
I can levitate!
Mr.Green's Avatar
I hate to admit it, but Cerial is rite. He used way too many words but his is wright.
But you (GearDrive) are rong. You will not lose any volume with a ball valve, especially the proper sized ball valve. Quit being silly. Ball valve is your cheapest, simplist solution. Or spend more money on quick disconnects. You will love them.
Old September 19th, 2012, 08:03 PM   #20
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
I'm trying to figure out how volume is reduced with properly sized quick disconnects. They are used on everything.. Pneumatic, hydraulic, and water.
Page generated in 0.55163 seconds with 82 queries
