1996 K1500 Z71 350 Carb, - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2012, 01:27 PM   #1
chuck202003
chuck202003's Avatar
Default 1996 K1500 Z71 350 Carb,
I just bought a 96 K1500 Z71 from a friend, He has been having wiring issues so he pulled the vortec 350 out of it. I am going to put an old school carburated 350 in it and get rid of all the computer and wiring issues. I know I have to put a different transmission in it, I was thinking a turbo 350 but heard gas millage is gonna be bad. I was also told that I need a transmission that is 1988 or newer is this true? I am using the stock transfercase. What other problems am I gonna run into?
chuck202003 is offline   Reply With Quote
Old September 17th, 2012, 01:34 PM   #2
kevinr839
kevinr839's Avatar
Why not just leave the trans that is in it there and get a stand alone computer to run it if needed?
kevinr839 is offline   Reply With Quote
Old September 17th, 2012, 01:36 PM   #3
chuck202003
I was told I can get a manual valve body to put in it but then it would be manual with a ratchet shifter for $300.00 then pay to have it installed. I can get a 350 trans for $100.00- $200.00. Plus I do not have a $1000.00 for a stand alone computer.
Old September 17th, 2012, 01:50 PM   #4
kevinr839
kevinr839's Avatar
Does it have a cable that goes to the throttle from the trans or the big round plug in on the side of the trans?
Old September 17th, 2012, 04:03 PM   #5
Iggy
Iggy's Avatar
The 700-R4 (4L60) trans was used before computers. It was in 1993 models that they changed to the 4L60E, prior to that the only thing the computer controled was the lockup of the converter. There are many lockup kits on the market, consider trading the 4L60E for an earlier 4L60 and getting a lockup kit.
Iggy is offline   Reply With Quote
Old September 17th, 2012, 04:27 PM   #6
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
You'd be better off getting a TBI 350 rather than a carb 350. But for a carbed 350 you can use any transmission from 88-93 and 78-87, that's a 700-r4 or a 350 turbo. for the turbos you'll have to get a new crossmember and driveshaft(s), the 350 is shorter than the 700. You could use a 400 turbo if you wanted too
Seems like your making a lot more work for youself, what are the wiring issues your having??
Old September 18th, 2012, 12:01 AM   #7
TboneK1500Z28
question is why did you buy a truck with wiring issues. converting to carb on an 96 is more hassle than its worth in my opinion.
u can drop a whole tbi 350,700r4 combo in if you swap harnesses and computers
id run a 700r4 before i went and did a whole manual valve body swap cause who knows what you could find.
i say fix yor wiring issue. a three speed will not be very driving friendly. fix it the way it is would be your ultimate best bet.
TboneK1500Z28 is offline   Reply With Quote
Old September 18th, 2012, 10:20 AM   #8
chuck202003
Ive already bought the carburated 350 and I'm gonna drop that in. I bought the truck from a friend and he went through three different wiring harnesses. So i figured I would put a carb in it and bypass all the headaches of the wiring and computers. I sold the trans so I will need to put in the 700r4 or a turbo 350. My friends tell me the 700r4 will heat up while towing my mud truck. The truck has 33's and 3.73 gears so they say the gas milage wont be to bad.
Old September 18th, 2012, 10:53 AM   #9
Iggy
Iggy's Avatar
Sending a PM
Old September 18th, 2012, 11:32 AM   #10
TboneK1500Z28
trans cooler and youll be fine, u need to adjust the tv cable properly or say bye bye to the 700r4. i dont think 700r4 has electronic vss but i dont remember for sure. im just thinking if he went through three harnesses then it may not have been a harness at all, and more or less engine electronics or a faulty computer.
Old September 19th, 2012, 07:41 PM   #11
wave_crusher
I'll Direc your TV
Yea, definitely sounds like something more than a wiring problem...anyway
Just go with a 700-R4, or a 4L60. If it heats up while towing a mud truck your doing something wrong....if your really worried about it, get a aux trans cooler. And Yes, make damn sure you adjust the TV cable properly, or you'll destroy the new trans in a hurry.
Like I said; you'll need to replace some parts if you switch to a 350 turbo, and you really lose some mpgs
Old September 19th, 2012, 09:31 PM   #12
TboneK1500Z28
im all for the whole carbd 700r4 swap. but in reality you did mentioned driveability and your vortec 350 with 4l60e is far better at that then any carbd motor. if your going all out to buy a carb engine why not go to your pick n pull and grab a complete vortec and put it in i guarantee itd work, because your problem isnt wiring related its engine electronics related
Old September 19th, 2012, 10:03 PM   #13
deerebowtie
Unchained
deerebowtie's Avatar
why do all this bs when you could just fix what you have, or convert the top end of the vortec 350 to carb? this whole process is dumb and more costly.
Old October 23rd, 2012, 02:25 AM   #14
xjagain
completely right.The 700R-4 (4L60) is a far better transmission than the 350 turbo. They get a bad rap from people who understand them. There is an opposing helical cut gear set engaged in second gear otherwise known as a "hill holder mode". When plowing or rocking them to get unstuck an accidental reverse to 2nd shift can do significant damage, including breaking the sun shell, as they were only rolled from the factory not rolled and welded. Most 700R-4s that have been rebuilt have had this solved with an upgraded shell. Yes, they do occasionally over heat, but most K series had built in coolers in the radiator direct from the manufacturer. The radiator in the 96' should have an internal oil cooler as well as trans cooler.
Who doesn't want OD anyways?
xjagain is offline   Reply With Quote
Page generated in 0.36618 seconds with 65 queries
