AOD Transmission in 93 Cherokee Help needed! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2005, 11:39 AM   #1
shelbydodge
Default AOD Transmission in 93 Cherokee Help needed!
I have a 1993 Jeep Cherokee 150k on a 4.0/ Auto Overdrive trans. Recently the reverse lights have been working on & off along with it starting sometimes in Park or Neutral. I suspect it is the Neutral Safety Switch taking a dump. Has anyone ever replaced one of these $200.00/plus switches before? Is it a very hard process? I am new to this site and was looking for some imput. Thank You!!!
shelbydodge is offline   Reply With Quote
Old December 19th, 2005, 10:57 PM   #2
Tonka
Tonka's Avatar
pm Killer B, might take him a bit to get back to you, but he definately knows transmissions
Old December 20th, 2005, 06:41 AM   #3
FlatFender
Tap Tap Splat
FlatFender's Avatar
No need to replace the switch. It can be cleaned pretty easily. Go to www.naxja.org/forum and search for NSS, and it will have all the info you will ever need.
By the way, your transmission is an AW4.
Old December 20th, 2005, 06:59 AM   #4
shelbydodge
Talking
Thanks for the info!!!!!!!!!!!!!!!!!!!!
Old December 20th, 2005, 08:31 AM   #5
Yeah, PM the 'B..
I have a 1985 Toyota truck that I'm cutting up for the scrap yard this week, including the transmission. The Toyota 4 speed of the era was the A340H, which is the same trans as the AW4, only with the Toyota bellhousing and T-case adapter. I can see if the switch is an easy removal, and I'll try to pull it, just in case..
Old December 21st, 2005, 09:48 AM   #6
shelbydodge
Talking
Let me know, Thanks
Old December 23rd, 2005, 09:17 AM   #7
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
easy to pull and easy to clean
It's on the side of the tranny and comes off with one nut.
Old December 24th, 2005, 07:41 AM   #8
shelbydodge
Talking Many Thanks to all
Thanks again for all the help!!!!!!
Page generated in 0.20020 seconds with 47 queries
