| Home | Register | iTrader | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Store | Photo Gallery | Chat |
| The Pub A friendly forum where everybody is nice, and will answer any questions you have about life. |
Thread Tools |
#1 |
HEAVY D
Pole barn vs stick built
Looking for everyones thoughts im only doing a 28x32 12' tall wall im trying to keep price down and get the most for my money. What does everyone think? Im leaning towards the pole building my township only calls for a 18" rat wall made of treated lumber. Everything I keep reading seems like pole build will save me around 4500 in foundation work and the rest will cost around the same.
#2 |
missmrgreenagain
Do u ever plan on finishing the inside
H.o.r.e cheap gears [url]www.ronsmachiningservice.net[url] tube bending and gear installs pm me for info! gears installed for $150 and up per axle. |
#3 |
When I have priced them myself looking at lumberyards, for the most part, you are correct on the materials prices. Depends on how you planned to side and roof it as well. The main difference is in the foundation. I think its easier to go very base bones/basic with a pole barn, but as bigbcehvy says, the nicer you want to finish it in the end, the more a stick built makes sense.
I'm having Orchard construction in your town do mine this fall, 30x40x12 pole structure. |
#4 |
Insomniac
Pole barn will go up faster, cost less, and there is a lot you can do yourself as far as insulation, electrical, and finishing. The foundation and walls will be your highest cost. Use steel on the roof and walls to cut down cost. Make sure that you do not scratch the steel as you install it to reduce rust. Choosing dark brown as a steel color will hide rust that will happen over time.
If you know someone that does spray foam it is a great improvement over traditional insulation. 2" of spray foam( check your local code) placed down before the electrical will let you install the electrical later like during the winter from the inside. You can prep the foundation before hand leveling the area cutting down a good amount of your cost. The amount of fiber in the cement will increase your cost. Depending on what you plan on placing on the cement such as a post lift or such you may need a thicker foundation in spots to avoid cracking around the post. Look up the codes in your area and see what you can do as far as cutting cost. Spending a bit more now will be worth it. There are a few areas like the insulation where you can save money on it now while being up to code. At a later time you can add more insulation if you feel it is needed. Other areas like the foundation and thickness of the floor is where you should focal your funds with the final and future plans in mind. |
#5 |
HEAVY D
The only thing id pry ever do is 4x8 sheets of foam board to half ass insulate it & maybe put up the panels like what ive seen other farmers in my area use but i'd never drywall or anything if thats what your asking.
#6 |
HEAVY D
Just planning on steel roof & siding just going to color match the house. I do have to put brick 4' up then siding on the wall facing the street bc from the road it needs to match the house the township says.
#7 |
Devout Atheist
![]() Join Date: 11-08-05
Location: A little North of Deetroit and a little South of Roseville
Armada can be pricks. Do what the city inspector says to avoid headache.
Don't die a virgin, there are terrorists up there waiting for you! |
#8 |
Trailer Trash
He is moving to bruce twp.
-1993 Ranger 3.0 4X4 5 Speed STX -A Metric Butt ton of three wheelers -1985 V65 Magna -1983 Nighthawk 650 -1969 F250 Highboy built 360 |
| Thread Tools | |
