4.3l wont start after swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 12th, 2012, 05:09 PM   #1
gli_ryan
gli_ryan's Avatar
Default 4.3l wont start after swap
I picked up a 93 cpi blazer, drove it onto the trailer when I took it home. I swapped the 4.3 into my postal cj. Its all wired up, good to go right? Wrong. I can't get it to start. I've pulled a plug to check for spark, doesn't seem to be sparking or getting fuel. I checked the old key and it isn't one of the resisted ones, I'm using a different key switch anyways.
Fuel pump is priming when key turns to on position. There is power at the ignition coil. I just tried replacing the ignition control module and didn't get any farther in the issue. I'm stuck as to what the problem is.
gli_ryan is offline   Reply With Quote
Old September 12th, 2012, 05:44 PM   #2
gli_ryan
gli_ryan's Avatar
got it, wiring was incorrect and ecu was not getting power during cranking. I still haven't gotten it to start though. The motor will turn over, then stop, then turn over more. I am guessing that when its stopping there is a cylinder somewhere thats firing off, can't hear a pop though. Timing likely way off?
Old September 13th, 2012, 08:18 AM   #3
knaffie
knaffie's Avatar
Is your fuel pressure in spec?
Old September 26th, 2012, 03:00 PM   #4
luckeylucas
joe is my bff
luckeylucas's Avatar
Crank position sensor?
luckeylucas is offline   Reply With Quote
Old September 26th, 2012, 08:44 PM   #5
gli_ryan
gli_ryan's Avatar
Timing was/is way off.
Old October 13th, 2012, 11:28 AM   #6
gli_ryan
gli_ryan's Avatar
Bringing this back. Put a couple relatively trouble free miles on this, and a missfire started to show up. It kept getting worse. Also it would never idle on it's own. It would idle for a few seconds at best and then abruptly die. Replaced the idle controller, tps, and the cts. Nothing fixed the issues. Now it wont run at all. Tried all sorts of timing stuff, nothing fixed it. Pulled the intake and all the poppets looked clean, all sprayed, and none stuck open. Checked out the distributor, nothing was broken their either. Put it all back together and it still isn't even trying to fire up. Checked compression, all between 130 and 140, coil is sparking and the one plug I've been able to check so far is also sparking.
I'm at wits end with this thing.
EDIT: running on ford e2000 fuel pump and a new fuel filter. When the missfire started to get worse between shifts the motor would completely die, seemed like a load issue sometimes.
Old October 13th, 2012, 01:28 PM   #7
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
did you check the distributor gear for ware? Mine acted like yours when, got worse when it shifted and at idle because when the load went away the gear had extra slop and caused the timing to go all to wack.
Old October 13th, 2012, 03:11 PM   #8
gli_ryan
gli_ryan's Avatar
Yeah, it seemed like it was minimal in terms of the wear. And the movement didn't seem too much that the rotor would turn. But now it won't even start, at all. It got worse quite quickly. I had just put 5 gallons of gas in it, and there were probably 2 or 3 gallons already in the tank. I'm going to add some more though, my neighbor was on the PD's most wanted list for burglary…potentially a siphoned gas tank? Doubtful as my poppets were spraying plenty of fuel but I'm going to give it another 3 or 4 gallons.
Old October 17th, 2012, 10:48 PM   #9
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Check the ignition module. It's easy to get at, cheap to replace, and intermittent when failing.
zook94 is offline   Reply With Quote
Old October 20th, 2012, 04:22 PM   #10
gli_ryan
gli_ryan's Avatar
Turned out to be a combination of cap, rotor, and wires. I've never had any experience of failure of these parts quite like that, nor have I even heard of that before. I checked the cap and rotor before installing the motor, and they looked really good. When I just checked the cap contacts were bad, replaced them and it fired right up. Replaced the plugs/wires because I think the wires may be damaged. It's still missing at idle intermittently though, but will go down the road just fine. I was excited, and wanted to check clearance and what not...
rear is stuffed up all the way, shock is stopping it from going up more. front seems to have another 1" or 2" of up travel.
Page generated in 0.33468 seconds with 53 queries
