Misc Jeep Part(s) lots of cj and other jeep parts more parts added nov/2 - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2012, 09:34 AM   #61
jhew
I'm looking for a heater system for an 83 cj-7 & a tilt steering column as well
jhew is offline   Reply With Quote
Old November 8th, 2012, 09:37 AM   #62
Wramblerguy
Wramblerguy's Avatar
I've got heaters
And a couple straight columns but we are out of tilt columns
3rd generation jeeper
Old November 11th, 2012, 07:14 AM   #63
Mijeeper CJ 7
Mijeeper CJ 7's Avatar
Originally Posted by Wramblerguy View Post
I've got a couple
you've got PM
Mijeeper CJ 7 is offline   Reply With Quote
Old November 11th, 2012, 09:46 PM   #64
Clyder
Clyder's Avatar
I have an "86 cj with a stock front axle that is bent. Do you have a dana 30 that would fit, or even better an dana 44 that would fit?
Clyder is offline   Reply With Quote
Old November 11th, 2012, 09:49 PM   #65
Wramblerguy
yes i have a wide track dana 30, do you know your gear ratio?
i also have a scout dana 44 housing with gears that would work
it would need shafts out though
Old November 13th, 2012, 11:19 AM   #66
82cj7ltd
Saved by Grace
any one piece amc 20 axles?
how about gearing set ups for the amc 20/d30? Have ring and pinion sets for 3.07 or 3.31 axles? I have the 2.72 ratio... will I need a new carrier?
maybe it's better for me to just buy axles from you and not re-gear mine...????
82cj7ltd is offline   Reply With Quote
Old November 13th, 2012, 11:28 AM   #67
Wramblerguy
I know a guy with a set of narrow trac one piece shafts
We could probably do some gear set up if necisarily
And I believe the carrier break on a 20 is 373
I do have a amc20 with 354 gears
I'm not sure about a matching 30 though
Old November 13th, 2012, 11:46 AM   #68
82cj7ltd
Saved by Grace
gotcha ok. well I have wide axles right now and I'm looking to keep those..... just didn't know if you had any widetrack 1 pieces.... or maybe new axles altogether. should've mention I didn't want narrow trac sorry.
hmm I'll have to see if I want to go as high as 3.54
Old November 13th, 2012, 12:16 PM   #69
Wramblerguy
Well I have a few axles I'm just not sure of what the ratios are
I might have sone 3.31 or something
But why wouldn't you want to go to 3.54?
Old November 14th, 2012, 03:51 PM   #70
82cj7ltd
Saved by Grace
hmmm well the gear calculators I've used just make it look to me like that going to a lower gear such as 3.54 will just have me turning higher rpm's around town and such than would be desirable.
If I was going to be running the 258, I think I would do that... but I thought that was a lower gear than I'd want for streetability. I guess I'm especially thinking of the freeway.... but I guess if I get up to that high of speed.... I'll have things to worry about besides the engine speed.....
Old November 14th, 2012, 05:03 PM   #71
Wramblerguy
Pm sent
Old November 14th, 2012, 09:45 PM   #72
Wramblerguy
i can deliver most parts as far as the intersection of 94 and 66 in battle creek since i am working there a few days a week
Old November 26th, 2012, 11:06 PM   #73
Wramblerguy
bump
Old January 1st, 2013, 08:38 PM   #74
Wramblerguy
Up
Only one wide track 30 left
Old January 7th, 2013, 07:58 PM   #75
jesseb
jesseb's Avatar
Thanks for the parts.
jesseb is offline   Reply With Quote
Old January 7th, 2013, 08:45 PM   #76
82cj7ltd
Saved by Grace
pm'd
Old January 7th, 2013, 10:30 PM   #77
Wramblerguy
pm'd
replied
Old February 14th, 2013, 02:06 PM   #78
Wramblerguy
Up
Old February 18th, 2013, 11:37 AM   #79
Wramblerguy
Up
Old February 18th, 2013, 11:54 AM   #80
shaggy
shaggy's Avatar
any radius arm 44s or ford 9"? and if not a ford 8.8?
shaggy is offline   Reply With Quote
Page generated in 0.57395 seconds with 83 queries
