Thread Tools
Old September 11th, 2012, 09:40 PM   #1
Wramblerguy
Wramblerguy's Avatar
lots of cj and other jeep parts more parts added nov/2
what i believe is a 44rh, it is out of a wrecked low miles 5.2 grand cherokee $250
a complete 249 from behind the trans $75
249 parts including a good viscous coupler $20
6 lug dana 44 with disc brakes and 4.30 gears about 60"wms $300 SOLD
lots of stock and after marked drive shafts from cjs and yjs $50 depending on condition
a set of narrow track dana 44 axle shafts $50
jeep peddle assemblies auto and manual $25
lots of jeep axles nt amc 20s $50-100
scout dana 44 front housing and gears, $75
1wide track dana 30$50
dana 44&53 with 4.10s out of a j truck $200
lots of cj nt dana 30 shafts $50 each
dans 300,20,and 18s whole and parts
scout dana 300 with "texas" pattern $350 sold
a stack of jeep aluminum bell housings $50 each
various 3 speed transmissions
stock cj heater assemblys $100
76 amc 360 its been stored inside for probably 10 years it rotates and probably wouldnt take too much work to get started $250sold
3 york compressors $50 each
lots of cj steering boxes $50 each
3 cj7 hoods $50 each
jeep t4 with 10 spline input $100 SOLD
t15 3 speed $75
weber carb set up on aluminum 258 intake $100
lincoln portable welder with 2 cylinder onan motor, runs $500
rear window for a cj7 hard top not rusted in very good condition $100
locar shifter for th350 like new condition with all parts $100 sold
i have 2 stock 231 main shafts and tail housings, one chevy one jeep $20 each
fiberglass cj7 tailgate painted yellow with a big ford symbol painted on it $100
carr light bar for a jeep chrome $50
dana 44 2.73 gears and carrier 2 sets $20each
stock jeep/chevy knuckles 2 sets $20 each
steel cj7 tailgate one side of hinge bolts broke off but mostly rust free $100
lots of little things, many jeeps have been parted out to create this collection
i can get pictures of any items easily i just dont want to clutter the thread
i know im forgetting things just ask and ive probably got one
all prices are obo all reasonable offers will be considered
3rd generation jeeper
98 grand cherokee dd
90s wrambler efi 2.5, t5, sye231 ,d44s locked with 4.88s
http://www.greatlakes4x4.com/showthread.php?t=236415
Old September 12th, 2012, 07:44 PM   #2
Wramblerguy
bump
Old September 13th, 2012, 02:52 PM   #3
mandrews90
i need a pedal set up for a cj with an auto...any chance you would have one. if so please call me mike 810 343 2641
mandrews90 is offline   Reply With Quote
Old September 13th, 2012, 03:30 PM   #4
Wramblerguy
Yes there is a couple pedal assembly's
Old September 15th, 2012, 09:58 PM   #5
Wramblerguy
bump lots of parts it would take all day to list them all
Old September 23rd, 2012, 11:17 AM   #6
Wramblerguy
bump
Old September 23rd, 2012, 01:08 PM   #7
85toy4runner
don't suppose you have a t176 4 speed laying around?
85toy4runner is offline   Reply With Quote
Old September 23rd, 2012, 02:50 PM   #8
Wramblerguy
No t176
I have a t4 4 speed and 2 435 in pieces you could maybe make one good one out of
Old September 30th, 2012, 05:37 PM   #9
Wramblerguy
more added
Old October 1st, 2012, 10:04 PM   #10
Wramblerguy
package deals available, the more you buy the cheaper it gets
Old October 2nd, 2012, 07:57 PM   #11
Mich Trailblazer
Mich Trailblazer's Avatar
My nephew has a '84 CJ-7 sitting in my yard with a blown-out rear diff. Would you happen to have a wide-track AMC20 that I could have him get so this yard orniment could leave my yard?
Mich Trailblazer is offline   Reply With Quote
Old October 2nd, 2012, 09:32 PM   #12
Wramblerguy
Last time counted I think there was 7 amc 20s
Could prolly make you a prety good deal
Do u know what is broke on it or do u know the gear ratio
Old October 3rd, 2012, 05:36 AM   #13
bdavid
bdavid's Avatar
need a good front shaft for a 4'' lifted wrangler. How much ?
bdavid is offline   Reply With Quote
Old October 3rd, 2012, 06:32 AM   #14
Wramblerguy
I don't know if there are any that long
Get me a measurement
Old October 3rd, 2012, 11:38 AM   #15
Mich Trailblazer
Sorry, I have not had the time to open up the diff to see what exactly is scattered, but the previous owner told him the spider gears exploded. Basically, you start the Jeep, put it in gear, let out the clutch and you hear a grinding noise from the rear and no movement of the Jeep. The rear is not seized up, for it will still roll if you push it, just no power transfer to the wheels. At the time he bought it, I was seeing all kinds of AMC 20's on here for sale from guys up-grading to a D44, 9-inch or D60. Then when he finally gets serious to fix it, no one has anything posted for sale!
Anyway, other than it being a wide-track, since it is a '84, I'm assuming something on the highway gear side. Do you know if AMC stamped the ratio on the axle somewhere? Or is pulling the cover the only way to determine the ratio?
I just figured an axle swap would be the quickest and easiest, since the current axle needs brakes and seals anyway. Figured get lucky and find another with same ratio, pick up some new u-bolts and swap. Or get really lucky and get a deal on a matching front and rear and swap both.
Old October 3rd, 2012, 12:11 PM   #16
Wramblerguy
well all the ones that are here would need brakes at the minimum because they have been outsided
there is probably a wide track 2.72 sitting back there or at the minimum a good canidate for some spider gears to swap
just check the tag on the cover if you can still read it
Old October 4th, 2012, 03:09 AM   #17
shindeldecker
shindeldecker's Avatar
Are the york compressors in good working condition
shindeldecker is offline   Reply With Quote
Old October 4th, 2012, 07:01 AM   #18
Wramblerguy
I have not tested any but they would of worked before and they have been stored inside since so idk
Old October 4th, 2012, 07:25 AM   #19
skoalman269
backwoods born
skoalman269's Avatar
Send a message via Yahoo to skoalman269
how many miles are on the amc 360 engine?
skoalman269 is offline   Reply With Quote
Old October 4th, 2012, 08:03 AM   #20
Wramblerguy
I believe it is fairly low
I want to say something like 80k but I will find out for sure tonight
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.20780 seconds with 50 queries
