Fan tower transmission and prop value - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2012, 07:22 PM   #1
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Default Fan tower transmission and prop value
Got a fan tower on my property that was used for keeping the frost off the apples. They have low hours but haven't been run since the early 80s ish. They are bolted to ford industrial big blocks. The blades are aluminum and approximately 12' span. Anybody know anything about these things?
Any idea what these motors are either? Can't find any tags or anything.
Sent from my PG86100 using Tapatalk 2
Old September 11th, 2012, 07:34 PM   #2
Paperman
Paperman's Avatar
Likely a superduty engine. Could be a 401,477 or 534. Are the fans usable or scrap?
Paperman is offline   Reply With Quote
Old September 11th, 2012, 07:45 PM   #3
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
The engines look like the old, old, old 372 blocks. Are the exhaust manifolds cracked? Particularly the right hand side manifolds. The manifolds are worth a pretty penny to restorers of Ford trucks that are next gen from the flathead V8's. The most expensive parts on those are the gear drive transmissions, that lower the output to the props. Get some numbers off of them, and hit some of the small aircraft/airboat websites. They go for good money too.
zook94 is offline   Reply With Quote
Old September 11th, 2012, 07:51 PM   #4
BlooMule
Old School
BlooMule's Avatar
I want one for a garage fan.
-rw-rw-rw
Old September 11th, 2012, 08:15 PM   #5
chadcooper55
I will get more info on them. From what I understand everything has low hours on it. It has just been sitting forever. I can make out on the valve cover "ford industrial". I want to get the motors off so it is easier to coyote hunt from up there
Page generated in 0.15738 seconds with 37 queries
