Busted irrigation pipe - when to fix? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 10th, 2012, 09:15 AM   #1
mtnbikinbryno
mtnbikinbryno's Avatar
Send a message via AIM to mtnbikinbryno
Default Busted irrigation pipe - when to fix?
Question for any irrigation guys - when is the best time to fix a broken line? (Apparently post hole diggers put holes in irrigation systems in addition to the ground) Right now I have the zone turned off, and I don't care if that particular zone isn't watered for the rest of the fall. Is it best to repair and/or modify a lines after the system has been blown in the fall?
Thanks.
mtnbikinbryno is offline   Reply With Quote
Old September 10th, 2012, 09:25 AM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
just fix it now
H.o.r.e
Old September 10th, 2012, 09:36 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
it takes about 15 minutes to fix it.
Old September 10th, 2012, 09:37 AM   #4
mtnbikinbryno
So it doesn't matter if the water is in the lines? That was the gist of my question, didn't want it to carry dirt down the line and mess up heads.
Old September 10th, 2012, 09:43 AM   #5
clarkstoncracker
lol
I would personally dig around the break. kick the zone on for a second to flush the dirt out of the line side of the hose, hook it up and run it.
all of your heads should have a built in filter... You won't mess them up.
I'm confused about you saying water in the lines.. You will probably end up using two couplings and four hose clamps.. water won't make the fix hard.
Old September 10th, 2012, 09:52 AM   #6
mtnbikinbryno
Cool, thanks. I don't know a lot about these systems, I didn't know if water sat in the lines when the zone is off. That's what I meant, versus waiting to have it blown out in the fall when they'd be dry for sure. I'll just fix it now.
Old September 10th, 2012, 10:36 AM   #7
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Fix it now so you don't get a bunch if crap in the lines. Do you have any hog ring pliers? Shoot me a pm with the line size and I will send you the correct clamps and fittings for the job so you don't get raped buying low quantity stuff
Old September 10th, 2012, 10:39 AM   #8
clarkstoncracker
lol
I've broken, added on, and spliced a ton of lines, I've always used stainless hose clamps and plastic insert couplings. Am I doing something wrong?
Couplings are $1.59, and the hose clamps are $.79...
Old September 10th, 2012, 11:01 AM   #9
Immortal
NO RELIGION WAT!
Immortal's Avatar
Well his screen name is hosejockey. Seems legit.
Old September 10th, 2012, 11:05 AM   #10
boggin-machine
boggin-machine's Avatar
hoser is correct
Old September 10th, 2012, 11:08 AM   #11
14muddn
The best time to fix your sprinkler is when it's broken.
Old September 10th, 2012, 11:13 AM   #12
jimhri
jimhri's Avatar
how about mid february when the temp is approx -10F
jimhri is offline   Reply With Quote
Old September 10th, 2012, 11:34 AM   #13
hosejockey4506
Visiting Admin
the correct way is to heat the pipe jam the coupler in there and then use a clamp like this.
maybe hog rings pliers isnt the correct name for the tool but thats what we call them.
Old September 10th, 2012, 11:36 AM   #14
hosejockey4506
Visiting Admin
Old September 10th, 2012, 11:52 AM   #15
mtnbikinbryno
Thank you sir, PM will be incoming after I can get home to measure the pipe. I appreciate it.
Old September 10th, 2012, 07:30 PM   #16
Yep, those clamps are what we always used, although never heated the pipes, just shoved the barbed fitting in, sometimes with a plastic mallet to help it.
You would also be fine with good quality stainless worm drive hose clamps. Couple bucks worth of parts.
Old September 10th, 2012, 09:15 PM   #17
Grassman
2jz specialist
Grassman's Avatar
you would be surprised how much a lil bit of heat on those lines makes the job easier. i think a 84 yr old woman could do it
Old September 10th, 2012, 09:33 PM   #18
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Oeitiker clamps. Heating the pipe sure saves the tennis elbow. Hose clamps work fine too.
Old September 10th, 2012, 09:35 PM   #19
Grassman
2jz specialist
Grassman's Avatar
like you would know
Page generated in 0.26913 seconds with 79 queries
