350 rad hoses - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2012, 09:20 PM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default 350 rad hoses
I have searched all day and cant find the answer. 95 yj with a 350 and an advance adapters rad( regular chev in and outlets) what applications should I be looking for, for upper and lower hoses. also if I measure right, the heater hoses are 5/8 and 3/4 right? I need applications because part # dont cross the border very well.
Old September 8th, 2012, 10:13 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
I was going to get THIS rad hose kit before I measured and looked at different hoses to see what would work with mods with my XJ small block swap.
Old September 9th, 2012, 01:17 PM   #3
Jeeper52
Jeeper52's Avatar
ttt
Old September 10th, 2012, 09:38 AM   #4
Jeeper52
Jeeper52's Avatar
anyone else?
Old September 10th, 2012, 09:57 AM   #5
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Bend a piece of wire in the shape and length you need and take it to the parts store and find something close. Shorten or lengthen as needed, that's what I did for my Chevy 4.3 to jeep rad.
Old September 12th, 2012, 06:28 PM   #6
Jeeper52
Jeeper52's Avatar
I did the wire thing and the application is as follows; upper hose is a 75-77 pontiac ventura-lower hose. the lower hose is for 97-2004 excursion 5.4l vin code L. A little trimming was necessary. but they fit great. 350 and advance adapters yj swap rad.
I sure hope this helps someone.
Old September 12th, 2012, 06:30 PM   #7
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Awesome work. When I did my swap, I just bought the flexxy hoses that had the right size end on them... I may purchase the ones you found. Can we have a pic of them in place?
Cheap Thrills Off Road
Old October 7th, 2012, 12:26 PM   #8
Jeeper52
Jeeper52's Avatar
these should show you how they fit . I had to cut some of the hose on the end(s)
Old October 7th, 2012, 12:29 PM   #9
Jeeper52
Jeeper52's Avatar
I would do anything not to use flex rad hoses.imho they put alot of strain on the rad. Ive seen more than a few copper rads cracked at the outlet and inlet joints
Old October 7th, 2012, 12:37 PM   #10
BigBird
BigBird's Avatar
Thanks, I will be going out o purchase some new hoses...
Old October 7th, 2012, 01:53 PM   #11
Jeeper52
Jeeper52's Avatar
these were goodyears if it makes a difference
Old October 8th, 2012, 10:25 AM   #12
FyrFyr
FyrFyr's Avatar
Does the lower hose have the inner spring? Thanks for the info.
FyrFyr is offline   Reply With Quote
Old October 8th, 2012, 11:41 AM   #13
Jeeper52
Jeeper52's Avatar
No it doesnt
Old October 8th, 2012, 10:47 PM   #14
FyrFyr
FyrFyr's Avatar
Thanks
Old October 20th, 2012, 10:37 PM   #15
stark2012
stark2012's Avatar
this has nothing to do with the rad hoses, but im going to be doing a 350 swap, what headers are you running?
stark2012 is offline   Reply With Quote
Old October 21st, 2012, 09:32 AM   #16
Jeeper52
Jeeper52's Avatar
If I remamber right they are block hugger, but I am using aluminium angle plug heads.I got them from summit. my only 2 options for thes were raw steel or chrome ,I got the chrome. One thing to watch for is the collector flange is welded too close to the header pipe and the collector flange wont allow a nut above
Page generated in 0.41331 seconds with 71 queries
