08 ls 5.3 motor all alum block 8000 miles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2012, 03:30 PM   #1
solid95yota
"the wonder truck"
solid95yota's Avatar
Default 08 ls 5.3 motor all alum block 8000 miles
i have a 08 ls 5.3 engine, it is out of a 08 impala ss. it is a all aluminum block and heads. motor only has 8000 original miles on it, i bought 2 weeks ago and in need of cash so have to sell, was told runs great. motor is very clean, has full motor harness, no ecm with it ( can pick one up from the junk yard for 40 bucks). has all the accessories on the motor water pump, a/c etc.. 1500 obo can call or text for questions or pics 734-307-8993 thanks
solid95yota is offline   Reply With Quote
Old September 5th, 2012, 03:31 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i will start the bidding
200 bucks
Old September 5th, 2012, 03:44 PM   #3
montecarlo33
The Violator
montecarlo33's Avatar
isnt that a front wheel drive motor?
Old September 5th, 2012, 03:46 PM   #4
solid95yota
"the wonder truck"
yes impalas are
Old September 5th, 2012, 04:53 PM   #5
firehawk
Live Action!
firehawk's Avatar
$350=tree fity
Old September 6th, 2012, 10:54 AM   #6
solid95yota
"the wonder truck"
Bump
Old September 6th, 2012, 11:31 AM   #7
cheapcherokee91
"cant worry about it"
cheapcherokee91's Avatar
that was quick
cheapcherokee91 is offline   Reply With Quote
Old September 6th, 2012, 03:39 PM   #8
solid95yota
"the wonder truck"
yea i tell ya
Old September 6th, 2012, 03:47 PM   #9
brian76708
brian76708's Avatar
200 bucks
$250
brian76708 is offline   Reply With Quote
Old September 6th, 2012, 03:49 PM   #10
InnerAirLock
Scout the Way
InnerAirLock's Avatar
Send a message via Yahoo to InnerAirLock
I would really like this!
InnerAirLock is offline   Reply With Quote
Old September 6th, 2012, 04:03 PM   #11
bbaXJ
Yooper In Training
bbaXJ's Avatar
Not trying to mess up the OP's sale by any means, but just so everyone knows, I believe the FWD engines like this one have entirely different mounting schemes for everything than the RWD setups do. Different accessories, and biggest difference is different bellhousing stlye/mounting so it won't work with the normal RWD transmissions. Someone please correct me if I'm wrong, but I seem to recall reading that before.
Old September 6th, 2012, 04:09 PM   #12
montecarlo33
The Violator
x2. I just did a 5.3 swap and I believe these engines wont work for a rear wheel drive setup, at least thats what I was told(same as quoted) when I was engine hunting.
Old September 6th, 2012, 04:38 PM   #13
buttercr125
I work out
buttercr125's Avatar
Yes these do have the 60* bellhousing bolt pattern. They will work in a rear wheel drive if you get the correct trans for it.
Old September 6th, 2012, 04:41 PM   #14
solid95yota
"the wonder truck"
yea, i just did some research cuz that was new to me also
This pattern has a distinctive odd-sided hexagonal shape. Rear wheel drive applications have the starter mounted on the right side of the block (when viewed from the flywheel) and on the opposite side of the block than front wheel drive. The 2.2l S10/Sonoma had the starter located in the same position as front wheel drive cars. A rear wheel drive bellhousing is displayed at right.
these are the bell housing that go to it
GM 2.8/3.1/3.4/3.5/3.9 L V6 (also used by AMC)
Buick 3300/3800 V6
Cadillac 4.1/4.5/4.9 L V8
Isuzu 3.5L DOHC V6
AMC/Chrysler 2.5L I4 found in Jeep Cherokee, Comanche, Wagoneer, CJ and Wrangler and Dodge Dakota
GM Iron Duke/Tech-4 2.5L I4
GM "122" 1.8/2.0/2.2 L I4
GM 5.3L LS4 V8
GM 3.5L LX5 "Short Star" V6
Old September 7th, 2012, 03:20 PM   #15
solid95yota
"the wonder truck"
bump 1350obo
Old September 10th, 2012, 09:25 PM   #16
solid95yota
"the wonder truck"
will trade for: chevy 205,chevy bellhousing for nv4500, 1410 yokes and flanges, 5.3 motor , coilovers, air shocks, air bumps, tube bender, fab tools let me know what u got
Old September 10th, 2012, 09:28 PM   #17
liv2mx
i like jungle gym's.
liv2mx's Avatar
damn you change your mind more then your brother...
Old September 11th, 2012, 04:27 PM   #18
solid95yota
"the wonder truck"
sadly enough that is true.... bump
Old September 12th, 2012, 09:28 PM   #19
solid95yota
"the wonder truck"
bump
Old September 13th, 2012, 08:55 PM   #20
solid95yota
"the wonder truck"
bump make some offers, or trades
Page generated in 0.35191 seconds with 83 queries
