Postal CJ - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 18th, 2012, 03:14 PM   #41
gli_ryan
gli_ryan's Avatar
Pulled cap/rotor. Noticed they were now burnt a little. Sanded them down and it fired up. Ran good for a couple minutes then started missfiring and died. Replaced them and it started right up and ran great! Then started missfiring after about 10 minutes. I'm thinking that my secondary problem was the cap/rotor, and my main problem is likely the plug wires. Possibly damaged and causing the cap/rotor to work too hard. Its still running really good, but at idle I can hear often a missfire. I'll replace the plugs and wires this weekend, and clean the cap/rotor again.
I've never heard of or experienced an ignition failure like this. When I put the motor in the plugs, cap, and rotor all looked really clean or new. That's why I never suspected these as the culprits. I'm happy I made tons of progress, unhappy at how much time I spent chasing ghosts.
gli_ryan is offline   Reply With Quote
Old October 18th, 2012, 04:41 PM   #42
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
check fuel pressure my old 4.3 did exactly this i heard the pump running normally and went for everything else in the end it was the one thing i was sure it wasn't pump ran fine but couldn't maintain pressure all the time sometimes it was fine not sure why replaced after several pressure checks with just key on and the the same at idle to find the problem
HPandThrottle is offline   Reply With Quote
Old October 20th, 2012, 03:44 PM   #43
gli_ryan
gli_ryan's Avatar
Yeah I checked that, was at 60+ psi the whole time.
Good news! So far at least, the thing is back to working. Drove it around for about 15 minutes and didn't get full on death wobble. But when going around a sweeping corner I hit a rough spot on the road and I could feel it starting to get into the DW. I slowed down so it would stop and it did. Got some good looks and "nice jeep!" cat calls.
rear is stuffed up all the way, shock is stopping it from going up more. front seems to have another 1" or 2" of up travel.
Old October 20th, 2012, 06:27 PM   #44
kmanxj5011
kmanxj5011's Avatar
That thing is awesome! Nice work.
kmanxj5011 is offline   Reply With Quote
Old October 23rd, 2012, 09:11 PM   #45
Irish Assassin
I really like what you are doing with it. Please show some more detailed pictures of the roll cage. i wouls like to see the inside tie-in's.
Irish Assassin is offline   Reply With Quote
Old October 30th, 2012, 05:11 PM   #46
gli_ryan
gli_ryan's Avatar
I'll snap some direct pics of the current mounting stuff on Thursday, school work for the rest of the evening….
Today I took the jeep on its maiden voyage. It worked very well! Minus the slow shifting from the t18. I put on at least 15 miles and hit 50 mph. It wasn't even scary at 50, which I was happy about. The bumpy road I went down sucked though, the roof is very loud on this thing. A couple of times I felt a little bit of death wobble, but it went away and didn't effect driving at all above 30.
Old October 30th, 2012, 05:42 PM   #47
deathbypsi
Brian R.
deathbypsi's Avatar
Awesome!
Old December 4th, 2012, 07:55 AM   #48
gli_ryan
gli_ryan's Avatar
Still need cage pics...although I think I really need to finish it due potentially to frame flex.
Well took this thing out for it's first attempt at offroading in the new configuration. Before going out I had to modify my transfer case crossmember. The drivetrain twists so much that my front drive shaft hits the crossmember. So I modified a mount with a hockey puck instead of a soft bushing, that didn't fix it. So I pulled the crossmember off, heated the area up, and beat it in with a 3 lb sledge. That gave me enough clearance it seems. No more contact at this point. I'd like to get more solid motor mounts though, I think this would help a ton (obviously).
A couple of things, my clutch linkage does not like frame twist (I assume thats what happened). But the spot I went up was rather level, so idk.. Attempted the first little hill climb. I was going super slow, and didn't expect to make it. To my surprise it easily crested the top and then started spinning tires, slowly mind you. So I tried to push the clutch in and roll back down. Well that didn't work, I lost half of my clutch throw so I couldn't disengage the clutch and I couldn't get it out of gear! By this time I had dug myself two big ole 38" tire holes. Shut the jeep off, couldn't get the drivetrain to release its pressure and couldn't get the trans out of gear. Ended up unlocking the front hubs, couldn't get them to unlock without a little movement though, so the front end stayed locked in. Jacked the back up and was able to get a tire off the ground and put the rear end in neutral, thank god for a twin sticked d20. Next step was jacking the front end up and kicking it off the hill, which worked fine.
Then I decided to try and adjust the linkage some, to get rid of some of the slack in the system. Well one of the rod ends broke instead, and thus no clutch. I tied a rope in place of that linkage part, which surprisingly worked. Although it only really worked twice and then was too loose lol. Got it into second and started it in gear, couldn't shift into third though… Got to the main road and was able to shut it off and put it in third, then start it. Got the the paved road and managed to shift it into fourth gear, and played my 1 potential stop at the highway safe and was able to get on without shifting out of gear.
Jeep goes down the road, smooth road, very very well. Bumpy turns I can start to feel the wheels wobbling, which is scary. I would like some shorter shackles to combat this. So the jeep is at my mom's, waiting to get a better linkage setup. I believe I will have to lengthen one of the levers of the clutch as well, so that I have more throw and control over the disengagement point of the it. I suppose I'll need to finish tying the cage into the frame, to help with frame flex.
here's where I lost pedal travel, I guess the rear tire there is pushed up some. Otherwise not much flex going on… Weird thing is when I did flex it out on a 33" tire, I don't recall loosing my clutch travel
and here's where I broke the linkage
Old December 4th, 2012, 09:08 AM   #49
deathbypsi
Brian R.
deathbypsi's Avatar
gota love workin out those bugs
Old December 4th, 2012, 09:21 AM   #50
hawkscj5
Skinny Pedal Crawler
hawkscj5's Avatar
nice! i like.
hawkscj5 is offline   Reply With Quote
Old December 4th, 2012, 12:14 PM   #51
gli_ryan
gli_ryan's Avatar
^Thanks!
I know…story of my life really.
Old December 4th, 2012, 02:11 PM   #52
Mr.Green
I can levitate!
Mr.Green's Avatar
I dig it.
Old December 4th, 2012, 02:43 PM   #53
srlbotanical
Because I Said So...
srlbotanical's Avatar
This thing is sweet.
I really like it. Nice job.
srlbotanical is offline   Reply With Quote
Page generated in 0.49578 seconds with 62 queries
