Common rattle? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2005, 07:25 AM   #1
Lothos
KD8GKB
Lothos's Avatar
Default Common rattle?
Ok, so I have the 4.0 with an auto. Sitting in D with the brakes on I tend to get quite a rattle ( quite less but present when in neutral). Whilst changing my starter I noticed that the entire exhaust assembly from the engine to the first hanger under the tranny has quite a bit of play in it side to side. I think this is the rattle I hear. The tail looks intact so am I to assume there is a break at the exhaust header?
Old December 19th, 2005, 09:45 AM   #2
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
that or it has come loose at that flange maybe... mine loosens up there all the time on my SBC from the movement while wheeling, though i get a nasty exaust leak too... if your header was broke i would assume you should be able to hear a nasty exaust leak too
Old December 19th, 2005, 09:49 AM   #3
Lothos
KD8GKB
Lothos's Avatar
Nope, no exhauist noise that I can tell there. That doesn't mean it aint loose/broke though.
Old December 22nd, 2005, 09:46 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
Check for adequete clearances around all your heat shields workin in a muffler shop all summer id say 90% of the cars like that came in were just a loose heat shield....
Old December 22nd, 2005, 10:18 PM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yea, loose heat shields on the cat, or other places...usually the cat though. Or rocks between the shields and the cat ot pipes.
Turn off the thing, get under it and bang on the cat with your hand...let it cool first...then bang all over the exhaust and see where the rattle is coming from. I use a rubber hammer for banging, but your hand will work too.
Old December 23rd, 2005, 12:39 AM   #6
Mclovin
"The Situation"
Mclovin's Avatar
I'll bet your wife loves you
Old December 27th, 2005, 09:20 PM   #7
Sonicjay
Yes, common rattle. What you are hearing is your t-case linkage rattling. Next time you hear it, lift the t-case lever slightly and I bet it stops. DCX makes a kit to replace the bushings because it happens so often. $33.25, Part number 5014148-AA SHAFT TRA 21005003
Sonicjay is offline   Reply With Quote
Old December 28th, 2005, 08:57 PM   #8
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
I agree ^^^^^^^^^^ i had this problem with my jeep and took care of it, and it hasnt rattled since, and my t-case shifter is a lot tighter now and easier to put in and take out of 4x4
Pongking23 is offline   Reply With Quote
Old December 31st, 2005, 08:08 AM   #9
Lothos
KD8GKB
Lothos's Avatar
My rattle is not from the Tcase linkage. While it does appear to be loudest when cold, it's definately vibrating with the engine and goes away as the rpm's increase.
Page generated in 0.20057 seconds with 50 queries
