Network Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2012, 09:21 PM   #1
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
Default Network Help
I am setting up a network at a truck terminal. I want to offer WiFi to the drivers that come in and out. Any ideas on a router that I can hook up an external antenna. The parking area is 3 acres in a squarish shape. the crossdock is in the middle.
I was thinking of this
http://www.netgear.com/home/products...3210.aspx#four
with an antenna, but I dont know which one would be best
http://www.netgear.com/business/prod...s/default.aspx
any help would be appreciated.
thank you
fukkinrizzo is offline   Reply With Quote
Old August 30th, 2012, 09:25 PM   #2
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Go to a truck stop and ask the manager to see their set up?
Old August 30th, 2012, 09:37 PM   #3
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Stick with a Cisco dual antenna professional model as a router. They are the best for Access points, covering alot of ground, and having the ability to interchange antennae. I ran these access points in a warehouse in Nova Scotia for Gordon Food Service. The coverage was so great, that 200 foot out in the parking lot, there was full strength signal for 100Mbps, and no drop outs in the warehouse at all. The building was over 10K square feet, and used 5 AP's to cover the entire joint.
zook94 is offline   Reply With Quote
Old August 30th, 2012, 10:06 PM   #4
fukkinrizzo
im looking at this now. I called netgear. This seems better than any others I am looking at. http://www.netgear.com/business/prod...ts/WAG102.aspx#
Old August 30th, 2012, 11:47 PM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
NO.
You want to look at a Cicso unit, Professional line. Anything else won't be able to handle the volume, or outdoor interference.
Don't even waste time or money on anything consumer level.
Linksys is made by cicso, but in the application you want is not going to hold up.
Old August 31st, 2012, 06:27 AM   #6
Smiley
Smiley's Avatar
Originally Posted by Sandals View Post
NO.
Agreed. Also be aware that even a commercial level AP is only meant to have 20-25 connections at a time. So you are going to need more than one AP to cover the area.
I have 26 Cisco APs (lightweight; meaning they are just APs) connected to a central Cisco Wireless Controller in order to cover our manufacturing facility.
You can go cheap with a consumer all-in-one unit and have complaints, or do it right for more money.
EDIT: I just went to your last NETGEAR link and see that they recommented a lightweight access point - hahaha. A LWAP does not have an Internet modem or a router like the consumer product you listed in your first post.
Smiley is offline   Reply With Quote
Old August 31st, 2012, 08:23 AM   #7
jonzer12
Ciso, Meru, Aruba... you need to think business class/enterprise for 3 arces and a large number of connections.
jonzer12 is offline   Reply With Quote
Old August 31st, 2012, 08:56 AM   #8
deerebowtie
Unchained
deerebowtie's Avatar
12 or 24 port layer 3 poe capable switch
cisco 1xxx series AP with detachable antenna
1 watt amp
some lmr cable
a few crimp on ends
this antenna - Hawking Hi-Gain HAO15SIP Antenna
and 3 antenna adapter cables.
That would be a pro solution that will easily cover the entire area, but its a bit of $$. You could cut out the layer 3 switch if this is a user only network, and use a poe injector. Not as clean but saves a metric pile of cash.
Old August 31st, 2012, 09:04 AM   #9
Sandals
Fucking Zen as Shit
Sandals's Avatar
1 watt amp
some lmr cable
a few crimp on ends
There are a few decent single layer POE switches out there that can be had for a reasonable amount.
Old August 31st, 2012, 11:00 AM   #10
deerebowtie
Unchained
I know what you're saying Sandals
but are you sure that's a layer 1 device..... ;) hub v s switch. look at the osi model and rethink that one.
Old September 24th, 2012, 10:34 PM   #11
fukkinrizzo
this? http://www.cisco.com/en/US/prod/coll...78-630461.html
or
http://www.cisco.com/en/US/prod/coll...ata_sheet.html
I want gigabit lan, wireless with guest access, vpn ability to connect my house network to the office network.
Old September 25th, 2012, 09:57 AM   #12
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
If you are just doing site to site you probably only need Ipsec VPN so the rv180 would work
TJJEEP is offline   Reply With Quote
Old September 25th, 2012, 09:05 PM   #13
fukkinrizzo
I just read the reviews on newegg. not very good for the 220, ok for the 180.
maybe I should get one without wireless and add an access point later?
Page generated in 0.31207 seconds with 61 queries
