Rear defrost not working - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2005, 07:22 AM   #1
Lothos
KD8GKB
Lothos's Avatar
Default Rear defrost not working
Ok, I am quite puzzled with this one. The window grid is intact perfectly. The contacts for the grid have been cleaned and as well as the connection between the harness and the hard top. I even get 12+ volts measured across the grid connectors with the system turned on. Yet I get no ice melting/fog clearing power. If you breathe on the glass when cold you get a faint hint that something might happen, but nothing. How can I have 12volts at the and the grid not working even though there's not a single nick, cut, or scratch in the grid lines?
Old December 20th, 2005, 11:18 AM   #2
Lothos
KD8GKB
Lothos's Avatar
Oh come on. Nobody?
Old December 20th, 2005, 11:44 AM   #3
Do you have current measurement capabilities on your meter?
Or, barring that, what is the resistance measured across the EBL? (Electric Backlight, as we call them in the business, for some reason..)
Having ~12 volts indicates the power feed is OK, but doesn't indicate whether there's any current flow..
Old December 20th, 2005, 05:29 PM   #4
clarkstoncracker
lol
clarkstoncracker's Avatar
What Jesus said.
Having volts is one thing, but if there is zero resistance, thats another.
Do you have a fluke capable of measuring this?
If you do, post the amperage.
Old December 21st, 2005, 10:47 AM   #5
Lothos
KD8GKB
Lothos's Avatar
I'll have to check when i get home. Don't have time here at work to take the fluke to it.
Old December 24th, 2005, 02:15 PM   #6
Lothos
KD8GKB
Lothos's Avatar
K, checked both sides of the EBL and I get 0 amps ( yes, i know how to measure current :) ) Reading the FSM again.
Old December 27th, 2005, 11:05 AM   #7
Lothos
KD8GKB
Lothos's Avatar
ideas?
Old December 27th, 2005, 09:18 PM   #8
Sonicjay
I installed the factory harness in my TJ after purchasing a hardtop. I scanned the directions to a PDF. It should show you everything that has to do with it:
http://www.sonicjay.com/jeep/hardtop...ss-install.pdf
Hope that helps
Sonicjay is offline   Reply With Quote
Page generated in 0.19971 seconds with 47 queries
