95yj rear Shock relocation - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2012, 01:44 PM   #1
spiderman32
GETTING THERE
spiderman32's Avatar
Default 95yj rear Shock relocation
So i have seen on some other jeeps that the rear shocks are relocated up into the wheel well. i want to make sure that i do it right and i never got a chance to ask about it. So is there a bracket that is welded to the frame and shock is attached there and where/what do i attach to on the axle??? plz help on this.
spiderman32 is offline   Reply With Quote
Old August 30th, 2012, 02:41 PM   #2
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
cut yours off and put them where you want, or buy new ones. I never understood why they hang that low...
Old August 30th, 2012, 04:22 PM   #3
DatcKid
Helping a friend with a custom lift on a tj...
Has the front and rear shocks relocated using ford shock towers. As far as the bottom mounts, they are up to you...stick em on the axle where they look good and make sure you're shock won't bottom out or compress too far.
Look up 97flexy on jeepforum or wranglerforum. He will answer any questions you have...also does a good job of explaining it in his build thread
DatcKid is offline   Reply With Quote
Page generated in 0.15118 seconds with 32 queries
