97 Xj D30 Outer Shaft - Rust Spot Okay? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2012, 08:42 PM   #1
RAVC1
RAVC1's Avatar
Default 97 Xj D30 Outer Shaft - Rust Spot Okay?
In disassembling my D30 I noticed this rust spot that is 2.5 - 3 mm in diameter at the outer edge of the machined surface for the seal. You can see the micro-polished line on the left where the lip of the seal rides. Will this shaft be okay to use given the location of the rust spot?
What does the increased OD at the right edge of the rust spot contact?
Thanks,
Rick
RAVC1 is offline   Reply With Quote
Old August 29th, 2012, 09:13 PM   #2
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Run it
Page generated in 0.21152 seconds with 30 queries
