Power Steering Filter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 28th, 2012, 12:45 PM   #1
JeepinJoe
Tear it up!
JeepinJoe's Avatar
Default Power Steering Filter
I'm looking to add an inline power steering fluid filter to my power steering system. Which line does it go in? Fluid flowing from pump to gear or from gear to pump?
Thanks
JeepinJoe is offline   Reply With Quote
Old August 28th, 2012, 12:55 PM   #2
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Why?
Old August 28th, 2012, 01:23 PM   #3
Gr8wht2000GMC
Gr8wht2000GMC's Avatar
If you feel the need to add one it should be in the return line (to the pump). Although I'm not sure what conditions you see that make you want to add a filter.
Gr8wht2000GMC is offline   Reply With Quote
Old August 29th, 2012, 07:19 AM   #4
JeepinJoe
Tear it up!
JeepinJoe's Avatar
Just looking to add some longevity to my steering system. A $30 filter is much cheaper than a new gearbox or pump. Thanks for the info.
Old August 29th, 2012, 08:32 AM   #5
92FleXj
92FleXj's Avatar
Do you have a cooler? Or a secondary resi? If not than that's what I would add to extend life. The cooler the better!
Old August 29th, 2012, 08:42 AM   #6
michigan maniac
michigan maniac's Avatar
Install it on the low pressure return line, I've installed them at work before, we do it whenever the pump, gear box, or rack and pinion internally fails, and has possibly let metal shavings or debris into the system
Old August 29th, 2012, 09:32 AM   #7
92FleXj
92FleXj's Avatar
Do you use an inline trans filter?
Old August 29th, 2012, 09:44 AM   #8
deerebowtie
Unchained
deerebowtie's Avatar
technically everyone does.
edit..with an automatic.
Old August 29th, 2012, 11:51 AM   #9
92FleXj
92FleXj's Avatar
Old August 29th, 2012, 12:21 PM   #10
deerebowtie
Unchained
http://www.jegs.com/i/Trans%20Dapt/9...0002/-1?CT=999
and here are the various brand/model filters you can use with that adapter
AC PF2
Baldwin B-2
Bosch 0-451-104-001
Deutsch D539
Donaldson LFP17-0008
Fleetguard LF3313
Fram PH8A
Goodyear L-8A
Hastings P115A
Kendall K1
Knecht OC-4
Lee LF-1A
Lucas F-678
Motorcrap FL-1A
Napa 1515
Pennzoil PZ-1
Purolater PER-1A
Toyota 15601-41010
Wix 51515
Page generated in 0.23549 seconds with 53 queries
