standalone tbi 454 injectors not firing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2012, 01:13 PM   #1
gregy133
killer
gregy133's Avatar
Default standalone tbi 454 injectors not firing
I pulled the 454 from a 92 gmc 2500 with a manuel trans. I have the whole engine wiring harness with a 1228747 ecm. I am able to crank the engine but can only fire if I spray gas in it. I can just the injectors to fire but the ecm isn't firing them. Any help would be great
gregy133 is offline   Reply With Quote
Old August 27th, 2012, 09:21 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
possible bad ignition control module or bad distributor pickup coil. the computer needs this input in order to fire the injectors.
Old August 27th, 2012, 09:24 PM   #3
deerebowtie
Unchained
deerebowtie's Avatar
check fuse ecm B. if its smoked the injectors won't pulse. also make sure you have a good ground to engine and fuel pressure.
Old August 27th, 2012, 09:45 PM   #4
gregy133
killer
gregy133's Avatar
going to try to change the distributor tomorrow. had people say they fought problems like this just to find out it had a weak signal coming from it
Page generated in 0.25493 seconds with 35 queries
