The predator shed.. - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2012, 11:09 AM   #41
big86inthestixx
big86inthestixx's Avatar
Standard 100watt curly bulbs, 20 of them.
White ceiling helps alot, so will white walls..
Sent from my SPH-D710 using Tapatalk 2
Old October 21st, 2012, 05:34 PM   #42
big86inthestixx
Got the first coat of most the primer on the walls of the barn tonight.
What a pain, i tried two different sprayers, kept plugging up so i thinned it, still kept plugging the tips and guns.
So back to old fashioned roller and a brush.
Seems even brighter yet..wahoo.
Got my pex/plumbing all roughed in too.
Heres a pic of the pex poking through the wall
Better hurry up, winters coming and projects are backing up..got to admit i like this pic of the jeeps in front of the barn
Thaaasts all for today..been lazy lately.
Old October 26th, 2012, 09:40 PM   #43
big86inthestixx
Well finall....two coats of primer and two coats of paint..then bingo...we got a super bright barn.. Excited, some cleanup and outlet covers, im moving in..
Old October 26th, 2012, 09:56 PM   #44
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Very nice
H.o.r.e
Old October 27th, 2012, 03:47 AM   #45
curbdog17
Mini Van
curbdog17's Avatar
Looks great. Nice work.
Old November 2nd, 2012, 08:41 PM   #46
big86inthestixx
Getting some crap from the garage moved over to the barn...
WOW what a mess you make working out of your garage..lol
Anyway getting different sections set up.
Climbing and chainsaws..
Cutting and grinding,
Of course the bandsaws still in the garage.
Tools etc..
Trying to keep it some what organized.
Now tomorrow maybe get some shelves built or the windows trimmed out in some sweet stainless trim..
After i help a fella with a lean to in kent city..
Old November 4th, 2012, 08:54 AM   #47
robn69
robn69's Avatar
Looking great!
robn69 is offline   Reply With Quote
Old November 13th, 2012, 08:33 PM   #48
big86inthestixx
Well been doing a little tinkering on organization..
Windows trimmed out
(think i already posted this)
Some organized shelving, for fluids, saws, misc...stuff
My compressor shelf, keeps compressor 5feet off the ground, them ill box it in with a small door to keep it a fuzz quieter..
All in all super happy with progress, and build. Wishing i had HEAT in there now...
Old November 13th, 2012, 08:40 PM   #49
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Saw it in person tonight, looks freakin great.
Old November 26th, 2012, 04:01 PM   #50
big86inthestixx
Well not alot of heat, but better than none..
Just been working in the barn, not on it..
Old November 26th, 2012, 04:15 PM   #51
sliter
the recovery guy
sliter's Avatar
nice.. its looking good
sliter is offline   Reply With Quote
Old November 26th, 2012, 04:39 PM   #52
big86inthestixx
Thanks guys..really getting sick of working on it. Not alot left, but so far it serves its purpose.
Need to:
Build steel rack for tube..etc.
Put compressor on its shelf and enclose
Install/build boiler (dont know what i want to do yet)
Pour lean to pad in spring.
Garage door openers
Trans benchs installed
Library (chiltons,etc.) Installed
A spare jeep parts shelf.
Old November 26th, 2012, 07:12 PM   #53
Easy_E
Web Wheeler !
Easy_E's Avatar
What's the plan for insulating above the steel ? Looking great so far !
Easy_E is offline   Reply With Quote
Old November 26th, 2012, 08:46 PM   #54
big86inthestixx
Already blew 10-12" of cellulose in. Something i noticed while doing that was how ridged the steel was, all screwed off, i could lay down between trusses on the steel, and it held...crazy.
Old February 19th, 2013, 08:57 PM   #55
big86inthestixx
Well been a few since an update on this thing. Still tinkering on it, little by little its getting closer to a semi organized shop.
So what ive done.
Spray foamed around all the doors and windows...wowza what a difference.
Set my compressor up on its shelf up off the ground, and temporarily piped the hose reel.
Also built my shelf across the rear of the barn, 9feet off the ground. Supported from the trusses above. Its a 41"x31' shelf...should holds lots of crap!!
After some serious looking and pondering i have also decided which boiler i want.
From a industrial HVAC pov, i am going with the "hawkins" owb the 2100 good for up to 10,000 square feet.
I decided this because,
Round burn chamber, less welds to possibly fail, plus some effiencies.
R38 foam insulation, ive seen what happens to spray foam over time in a higher heat environment...its not good.
On stilts, plus and minus..air can cool the bottom, which is bad...
Good..less rodent issues...maybe, steel wont rot out as fast..more comfortable loading, easier serviceability.
The warranty is great!
Has induced draft blower, so better faster heat recovery.
So that's mostly why i chose the boiler i did...
Now just need tax $$$$...lol
Sended frum da cumputar box in my hands eh.
Old February 19th, 2013, 09:17 PM   #56
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
So what ive done.
false
Old February 19th, 2013, 09:21 PM   #57
big86inthestixx
What makes u see that Honcho?
I understand that "flame" is not heat...but the blower would control the heat better, help have faster recovery times from the huge delta t from the in floor heat.
What would the advantages be to a natural/spring controlled draft?
Old February 19th, 2013, 09:29 PM   #58
Christmas Cookie
a natural draft is more than enough to keep up with a OWB. I looked into the forced draft for mine and found that, it wasn't needed, and uses more wood than needed to maintain temp on the boiler. I didn't read through your whole build, you are not planning on running the boiler water through that floor are you? I would hope you would have a secondary system with a t-stat on the floor side. And outdoor wood burners like flame not coals...coals get covered with ash and cannot keep up with demand
Old February 20th, 2013, 02:42 AM   #59
big86inthestixx
Yes im planning on running the boiler water through the floor, of course with a mixing vale to keep the temperature where it needs to be...like 80 degrees instead of 180.
Do i need a secondary source? I would think that if the concrete was set to 80 ish degrees that the whole building would maintain about a 60 degree temp....from what ur saying that's not whatll happen.
Old February 21st, 2013, 10:56 AM   #60
DirtyChevy
GOT MUD?
DirtyChevy's Avatar
Send a message via AIM to DirtyChevy
this is awesome good job man!!
DirtyChevy is offline   Reply With Quote
Page generated in 1.20841 seconds with 83 queries
