The predator shed.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2012, 09:13 PM   #1
big86inthestixx
big86inthestixx's Avatar
Default The predator shed..
Dont know if i can do this, but id like to share the build process and pictures of my new barn. The barn is a 32 x 38 x 12 with a 32 x 10 lean to, heated floors, all steel exterior, and 2-10x10 overhead garage doors. All of which is happening the same time im 4,Linkin the front of my jeep the "predator"
Got my lot cleared, cut and removed 65 trees. Had a blast and got a winters worth of wood.
Poles in, and holes inspected, now for some bracing.
Poles leveled, starting to install perlins to help hold everything together
Got the headers up and anchored to poles, soon...ill be setting trusses.
Got tresses set, need some bracing before ths big storm..
Got the top plates tied to the barn for the lean to, or as inspector calls it..a porch..
Front view of the barn with the porch rafters in, prett much ready for steel roof.
Got the roof steel installed and the small gable sided.
Got the 2" foam down, and 5x10 steel mesh to hold all the in floor heat pex.
Got all 1500 feet of pex zip tied down...wow the blisters on my pointer fingers are sore. Had to put up a circus tent since of course..the day i set to pour cement..its going to rain ALL day.
Cement is poured, turned out pretty good. Not bad..threw two drains in too.
Now i can go to town sheeting the outside..two tone. Gotta love the Amish..dirt cheap prices on steel.
Side view
Back view
House side view
Front view with garage doors installed..ran short on z bar and j Channel..so here i wait.
Finally got my supplies..all done outside
Got a killer deal on 70 sheets of OSB...5$/sheet. Of course a craigslist find. Had to unload 1 at a time...
Got my insulation today..so figured i better get busy before winter gets here.
That's all for now. Need to get jeep done.
Sent from my SPH-D710 using Tapatalk 2
Old August 25th, 2012, 09:20 PM   #2
green50gt
Got rocks?
green50gt's Avatar
1. I have a crush on you. 2. I've been really wanting and needing a pole barn myself, would you be able to give a rough estimate of what that might cost a fellow? I live in the heart of Amish country if that matters. In fact, I called three different builders this spring and none called back.
I heart Jeeps
green50gt is offline   Reply With Quote
Old August 25th, 2012, 09:26 PM   #3
92FleXj
stacks stacked on stacks
92FleXj's Avatar
I'm getting ready to put one up also, I'm very interested in how your going to do your heated floors. I have an outdoor burner I'd like to use to heat mine. I'm still exploring options.
Old August 25th, 2012, 09:26 PM   #4
92FleXj
92FleXj's Avatar
Best prices I've found in Michigan. Go on chelsealumber.com
Old August 25th, 2012, 09:32 PM   #5
big86inthestixx
I ran 5-300 foot loops of 1/2" barrier pex ran into 1" pvc long radius 90 where it comes through the cement floor. Then headered together, and piped to the boiler. But im only at the header stage, need the boiler yet, probably wont have it till mid winter. I also made my own water to water heat exchanger, similar to a side arm for your boiler to domestic hot water. Going to use it for hot water in the barn for the sink/hose.
Old August 25th, 2012, 09:34 PM   #6
92FleXj
92FleXj's Avatar
So you will run 2 pumps then?
Old August 25th, 2012, 09:36 PM   #7
92FleXj
92FleXj's Avatar
And also did you use insulation between your pipe and the ground before you covered with cement?
Old August 25th, 2012, 09:37 PM   #8
big86inthestixx
The steel price i got from the amish round here was 2.22/ft. The barns pretty prixy, building it myself ive dumped 18,000 into it already. But it is almost done. Would way rather have a wheelable jeep right now..but ill be happy when its done. Ill have plenty of room for all my fab tools..etc..
Old August 25th, 2012, 09:38 PM   #9
92FleXj
92FleXj's Avatar
You can get an erected 40x60 for under 19k
Old August 25th, 2012, 09:40 PM   #10
92FleXj
92FleXj's Avatar
But that is only a shell. Not all what you have going. It looks good.
Old August 25th, 2012, 09:48 PM   #11
big86inthestixx
Yeah..19..without cement, without in floor heat, without,insulation, without 2 tone, without overhead doors, without white steel ceiling, OSB, electrical, and all the site work.
All my interior perlins are 2x6, all my poles are 6x6, even around service doors.
Just saying..dont think its really apples to apples..more like apples to apple pie..
Old August 25th, 2012, 10:08 PM   #12
92FleXj
92FleXj's Avatar
I agree with you. Your is bad ass!
Old August 26th, 2012, 07:47 AM   #13
big86inthestixx
Yep i used 2", 25psi styrofoam on the ground before wire, and before pex.
Old August 26th, 2012, 07:52 AM   #14
capone
capone's Avatar
Nice job
capone is offline   Reply With Quote
Old August 26th, 2012, 07:56 AM   #15
bigbchevy
missmrgreenagain
bigbchevy's Avatar
looks great i like it !
H.o.r.e
Old August 26th, 2012, 08:19 AM   #16
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Looks great. Looks like it should be a great work area.
Old August 26th, 2012, 08:37 AM   #17
Easy_E
Web Wheeler !
Easy_E's Avatar
Great looking barn . What type of rolled insulation did you use on the walls ? Did you put anything between the outside stringers ? I need to do mine before winter.
Easy_E is offline   Reply With Quote
Old August 26th, 2012, 08:50 AM   #18
big86inthestixx
Yep i will be running more. One for house, one for barn floor, one for hw in barn, one for hw in the house.
I didn't do anything between outer stringers and 4x13ftx6"thick batts. On the roof u put a reflective insulation. I got all my insulation from Acme insulation..in downtown grand rapids.
Old August 26th, 2012, 08:56 AM   #19
jimhri
jimhri's Avatar
according to your photos, you just put a bundle of lumber on the ground, presumably add some water, and voila, a pole barn grows up!!?? gotta love it.
jimhri is offline   Reply With Quote
Old August 26th, 2012, 09:02 AM   #20
92FleXj
92FleXj's Avatar
i run one pump for my house, that covers HW and heat. im assuming you will need one to pump water to your barn and another to circulate the water through the floor.
Page generated in 0.40646 seconds with 83 queries
