Master cylinder question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2012, 12:07 AM   #1
03tjsport
Red Dragons!
03tjsport's Avatar
Default Master cylinder question
I have a yj with a d44 front using the ford calipers and in the rear I am using the gm metric calipers. The problem I have is that I have a very low brake pedal. Seems to be bled fine. No proportioning valve at this time. I may add one later. Any idea on which master cylinder to upgrade to? I have seen some things about e350,grand marquis,and corvette,but that only added to the confusion. Thanks!
03tjsport is offline   Reply With Quote
Old August 25th, 2012, 10:55 PM   #2
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I used the grand marquis master when I put my 60s in. I used stock yj prop valve. It will lock up all four 40s on pavement.
Old August 25th, 2012, 10:59 PM   #3
03tjsport
Red Dragons!
03tjsport's Avatar
I think I need to find a proportioning valve. Auto parts stores say they don't sell them. I am also going to check the pushrod length. I do not think my existing master is a jeep part.
Old August 25th, 2012, 11:59 PM   #4
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
a dodge ram master cylinder works well with big brakes too.
Old August 27th, 2012, 11:06 PM   #5
03tjsport
Red Dragons!
03tjsport's Avatar
So I pulled the master off and found that it was not seated properly to the booster. Needed to grind away some of the casting and chamfer the bolt holes. Also needed to lengthen the pushrod about 1/4". Seems to work fine. Locks up the front before the rear and has plenty of pedal.
Old August 27th, 2012, 11:17 PM   #6
deerebowtie
Unchained
deerebowtie's Avatar
http://www.speedwaymotors.com/Speedw...lve,24060.html
or
http://www.speedwaymotors.com/Wilwoo...ock,41747.html
Old August 27th, 2012, 11:34 PM   #7
Rob the plumber
Sweet. Did you figure out if it's the stock master and booster or not?
Old August 27th, 2012, 11:37 PM   #8
03tjsport
Red Dragons!
03tjsport's Avatar
I think the booster is stock. Still not sure on the master. I may need to post a pic. They seem to work well at this point.
Page generated in 0.27925 seconds with 47 queries
