weird taillight issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 23rd, 2012, 10:24 PM   #1
kj kyle
kj kyle's Avatar
Default weird taillight issues
I'm having an odd issue with my passenger taillight on my 06' jeep liberty. From what I can tell, both taillights work properly when the headlights are off. When I turn the headlights on however, the whole passenger taillight goes out when I apply the brakes. (The driver side works fine regardless.) Originally I thought a bulb had gone out, so I replaced all of them in the passenger taillight, it made no difference.
I have access to the wiring diagrams, and a multi-meter. I just don't know where to start.
kj kyle is offline   Reply With Quote
Old August 23rd, 2012, 10:36 PM   #2
CSFJ
offensive 2 the sensitive
CSFJ's Avatar
check your grounds. of all the oddball lighting issues I've run across, a bad ground is usually the problem
CSFJ is offline   Reply With Quote
Old August 23rd, 2012, 10:52 PM   #3
firehawk
Live Action!
firehawk's Avatar
Make sure you have the correct bulb in there, I put a wrong bulb in a 1998 Camaro and the headlight dinger kept going off.
Old August 23rd, 2012, 11:03 PM   #4
kj kyle
kj kyle's Avatar
welp, dumb mistake on my part, as usual.
I pulled the bulbs to double check, and you can insert them one of two ways. the left side has two contacts, and the right side as one. original post is the outcome if you have it backwards
Page generated in 0.25403 seconds with 35 queries
