Crew Cab, Crawler Hauler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 23rd, 2012, 05:32 PM   #1
GearDrive
A little slow
GearDrive's Avatar
Default Crew Cab, Crawler Hauler
Started out with an '83 Chevy crew cab, 6.2 diesel, 2wd.
Would of liked to of kept the diesel, but 140 hp and 250 lb-ft wasn't going to cut it. Neither was 2wd.
ID:	95916   Click image for larger version
GearDrive is offline   Reply With Quote
Old August 23rd, 2012, 07:07 PM   #2
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Oooh...always had a soft spot for double cabs....wedge or roll-back bed would be killer, but a decent comfortable gooseneck hauler is cool too.
Old August 23rd, 2012, 07:11 PM   #3
GearDrive
A little slow
GearDrive's Avatar
I converted it to 4wd using axles from a 79 GMC 3/4 ton with 4.10 gears.
Old August 23rd, 2012, 07:28 PM   #4
GearDrive
A little slow
GearDrive's Avatar
There just isn't much room in a standard cab.
Old August 24th, 2012, 07:13 AM   #5
GearDrive
A little slow
GearDrive's Avatar
The diesel was swapped out for a 500 cubic inch Cadillac engine.
Old August 24th, 2012, 07:55 AM   #6
XJcoupe
1ton XJ
XJcoupe's Avatar
nice- I run the same but on BBQ Juice
Old August 24th, 2012, 08:44 AM   #7
GearDrive
A little slow
GearDrive's Avatar
The stock rocker arm assembly is very weak when using higher pressure valve springs. I made my own assembly that is alot stronger.
Old August 24th, 2012, 01:48 PM   #8
GearDrive
A little slow
GearDrive's Avatar
This engines ideal cruise/tow RPM is about 2500. With 4.10 gears and a turbo 400 trans. @ 70mph, calculates to a 40 inch tall tire. I'm going to try a 37" tire.
Old August 24th, 2012, 03:04 PM   #9
0llllll0
JeepJohnson
0llllll0's Avatar
Nice! I will be watching this thread, as I have a 91 V3500 Crew and these are my favorite trucks. And the 500 Caddy is a sweet touch!
Jeepjohnson
"Black Foot" my CJ-7 build
Do you have a YJ ? Is the rear Frame rusted ? Check this out YJ Rear Frame Reinforcement Plates
0llllll0 is offline   Reply With Quote
Old August 27th, 2012, 06:59 AM   #10
GearDrive
A little slow
GearDrive's Avatar
More Cadillac parts. Installed 2005 CTS, full power, heated leather seats. Major floor modifications required.
ID:	96052   Click image for larger version
Old August 27th, 2012, 09:12 AM   #11
GearDrive
A little slow
GearDrive's Avatar
Here it is almost ready for paint.
Old August 27th, 2012, 01:38 PM   #12
GearDrive
A little slow
GearDrive's Avatar
Had the dash recovered.
Old August 27th, 2012, 01:53 PM   #13
GearDrive
A little slow
GearDrive's Avatar
This is how it sits today. Still need to wet sand and wheel the paint, and final assembly.
Old August 27th, 2012, 02:05 PM   #14
silveradoboy
Sam Brown
silveradoboy's Avatar
Wow that is fucking sexy! Good job!
Smokey burnout is in order when it is all done!
silveradoboy is offline   Reply With Quote
Old August 27th, 2012, 04:00 PM   #15
GearDrive
A little slow
GearDrive's Avatar
The studs broke off the "Silverado" fender emblems, $40 a piece to replace.
I designed these on my work computer, and had the cnc guys machine it.
ID:	96074   Click image for larger version
Old August 27th, 2012, 04:34 PM   #16
capone
capone's Avatar
Nice! Your truck looks great.
capone is offline   Reply With Quote
Old August 27th, 2012, 04:35 PM   #17
GearDrive
A little slow
GearDrive's Avatar
Thanks for the compliments.
Old August 27th, 2012, 04:54 PM   #18
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
NICE!
CHEVYRCKS is offline   Reply With Quote
Old August 27th, 2012, 05:21 PM   #19
tweak
Are we there yet?
tweak's Avatar
Looks awesome!
Old August 27th, 2012, 08:10 PM   #20
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
That is badass Neal!!!! Keep the pics coming.
ppkaprince98 is online now   Reply With Quote
Page generated in 0.38666 seconds with 85 queries
