d44 experts.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2012, 07:25 PM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default d44 experts....
Building a 78 f150 hp d44 for my ranger project but I have never payed much attention to d44 tech. Im planning to run the stock 3.50 gears {with a doubler} so I can street drive the truck as much as possible. My question is in regards to diffs for d44's.
When im out shopping for axle parts are all d44 diffs interchangable within the ratio breaks ? like the front to rear,ford,gm,jeep?
Not sure if I want to put a lunchbox in the stock open or maybe go with LSD.
Old August 21st, 2012, 10:38 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Yes.
Differential Case Breaks (or, "Do I need a new carrier?") - Great Lakes 4x4. The largest offroad forum in the Midwest
Originally Posted by Jeeperz Creeperz View Post
Dana 44 - up to 3.73 and 3.92 and higher
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old August 21st, 2012, 10:51 AM   #3
Pay attention to low pinion vs high.
Old August 21st, 2012, 03:10 PM   #4
deathbypsi
Brian R.
deathbypsi's Avatar
So a low pinion rear LSD wont work in my high front?
Old August 21st, 2012, 07:44 PM   #5
I was referring to gears specifically.
Old August 21st, 2012, 08:28 PM   #6
deathbypsi
Brian R.
deathbypsi's Avatar
Ok yes I knew that the low/high were different cuts. I just wanna start lookin for a diff and dont wanna buy something that wont work. I really think a LSD would work great in this truck up front.
Old August 22nd, 2012, 01:26 PM   #7
Complete Off Road
Complete Off Road's Avatar
I would recommend the True Trac if you talking about a front D44. True Tracs are biased differently for front and rear applications, so the front D44 TT is a little less aggressive than the rear version, making it pretty much invisible on-road.
Some other info for you - GM, Jeep, Dodge, and some Ford front D44s are standard rotation (low pinion). Most, but not all, front Ford D44s are reverse rotation (high pinion).
Complete Off Road is offline   Reply With Quote
Old August 24th, 2012, 11:36 AM   #8
John D
John D's Avatar
I found Mr. N's site useful when I did my 44.
http://77cj.littlekeylime.com/web_rs44.html
Old August 24th, 2012, 12:56 PM   #9
deathbypsi
Brian R.
deathbypsi's Avatar
Thanx John,lotta good info there.
Page generated in 0.38025 seconds with 51 queries
