What is a good clutch? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2012, 11:05 PM   #1
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Question What is a good clutch?
I know there are many brands, but I'm looking for a good one that will be good for what I do (DD and wheeling). I'm thinking about a Centerforce dual friction, but am unsure how well it performs. What do you guys run? Thanks I appreciate it
Old August 20th, 2012, 04:49 AM   #2
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I run a regular Valeo. It does everything it needs to without the stiff pedal.
Old August 20th, 2012, 05:45 AM   #3
RADRICK
RADRICK's Avatar
I have to wheeling buds that run the center force stage 2, one in a yj, other in tj. They both hold well (dont slip), pedal effort is not much over stock, but the centrifugal weights like to get hung up with sand/mud/dirt. If you frequent the mud, I would not choose the center force. I have heard good things about the LUK clutch, but I heard there throw out bearings are not that great. If I were to do a clutch in one of my jeeps it would be the LUK disk & pressure plate, and some other brand t/o bearing!
Old August 20th, 2012, 05:53 AM   #4
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Clutch Kit? - Great Lakes 4x4. The largest offroad forum in the Midwest
tcxtreme1000 is offline   Reply With Quote
Old August 20th, 2012, 06:27 AM   #5
yjynot
time to musk up
yjynot's Avatar
Lk pro gold. About 150 bucks shipped from partsgeek.com
yjynot is offline   Reply With Quote
Old August 20th, 2012, 12:33 PM   #6
99tj4banger
99tj4banger's Avatar
x2 on luk i bought the regular luk for my 2000 sport when my old clutch's throw out went. I bought the regular luk at pep boys, its been in my jeep for a little over a year now no problems I mostly dd with mild wheeling here and there. I went with the regular luk because they say luk is the clutch that comes stock in them. I didnt go with the luk gold because i didnt want the extra wear and tear on my master cyl/ slave.
99tj4banger is offline   Reply With Quote
Old August 28th, 2012, 10:30 AM   #7
skife
skife's Avatar
the best clutch
Old August 28th, 2012, 10:49 AM   #8
Rob the plumber
awww skeet!
Old August 28th, 2012, 11:03 AM   #9
BOGDOG
BOGDOG's Avatar
I've had the best results with the LUK clutches, been using them for years in Fords & Toyotas with no issues. Northern Auto Parts ususally has good prices on them.
Old September 3rd, 2012, 04:08 PM   #10
Renegade II
Coil springs are for pens
Renegade II's Avatar
I've been running Centerforce clutches for over 20 years through sand, mud & water without EVER having a weight get stuck or any other problem. Great hold and long lasting. I can't imagine how anyone with a PROPERLY installed bellhousing dust cover would get enough mud on a spinning flywheel/pressure plate to get the weights stuck.
Old September 5th, 2012, 03:46 PM   #11
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Run whatever Autozone sells you. Until you regear your going to be supper hard on you clutch. There's no reason to get a supper grabby clutch just to have to slip the piss out of it all the time. That's why I would just run an Autozone one for now and warranty it out when it dies (life time warranty).
Old December 2nd, 2012, 11:32 PM   #12
2fst4you
2fst4you's Avatar
Autozone ftw
Old December 4th, 2012, 08:10 AM   #13
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Autozone is what I'm running for now. Can't believe I had to order a Duralast clutch Lol. Seems like a clutch for a Jeep is something they would have kept on the shelf in a good size quantity. Duralast clutch is working good. Glad it has the warranty on it like my brakes.
Old December 4th, 2012, 09:07 AM   #14
bdd1469
bdd
bdd1469's Avatar
99% of clutch kits are made by one company,perfection. They are marketed under every name you can imagine duralast ,zoom,borgwarner,valeo just to name a few.
You can buy a duralast for less then $150 or a borg warner like I did for $225. Open the box and it is the same part number.
I think most problems with clutches going out prematurely in jeeps are caused be the rear main seal leaking oil all over them.
I have run hayes and centerforce in my cars for years,they work fine in most applications.
My third gen camaro runs a small 10 1/2" clutch disk.Every clutch I ever put in it would spin the tires a little in third gear,then slip the clutch. I put a spec stage three iirc in it and could do 500' burnouts in third,never smoking the clutch.
I would look at spec,or luk if I was putting another clutch in my jeep.The pos perfection clutch I put in held up fine except the plastic throwout bearing busted.
What ever brand you buy go to napa and buy a steel throwout bearing if it comes with plastic.
Old December 4th, 2012, 09:57 AM   #15
srlbotanical
Because I Said So...
srlbotanical's Avatar
x2 on the seperate throwout bearing. I put a NAPA kit (made by LUK) in a few monthes back and the TO bearing was all steel, recently a friend bought the same kit and the TO bearings are now plastic and stamped steel.
you want a TO bearing that looks like this:
Not like this (the one on top):
srlbotanical is offline   Reply With Quote
Old December 4th, 2012, 12:44 PM   #16
Rx7Kevin
yeah I dislike the weights in there, if/when they get dislodged you get an imbalance causing a nasty vibration and if it gets bad enough the circle of weights become off-centered and start to rotate funny and the weights will dig into the throw out bearing.
This has happened to me personally actually. After 2 throwout bearings in a year I just cut the weights off and used the clutch for another year or two without any problems.
Rx7Kevin is offline   Reply With Quote
Page generated in 0.43398 seconds with 72 queries
