Dana 60, 14 bolt 4.56 gears SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2012, 09:26 PM   #1
mud22
mud22's Avatar
Default Dana 60, 14 bolt 4.56 gears SOLD
Dana 60 4.56 ring and pinion on an open carrier. The roll pin that holds the cross shaft for the spider gears broke somehow and allowed the shaft to slide into the pinion gear, which marred up the end of the shaft and put a couple small chips in two teeth on the end of the pinion gear, which can be seen in the closeup pic. Will need a new cross shaft or grind the burrs off the damaged one but the pinion gear is fine. $100.00
14 bolt 4.56 ring and pinion on a 4.56 carrier with bearings and races still pressed onto carrier. No spider gears in carrier. Had a Detroit in it that I kept.
$100.00
.....or $175 for both.
I also have a 4.56 and up 14 bolt carrier with brand new bearings pressed onto it that I will throw in for free. And I have a 1350 series 32 spline yoke for a np205 t-case that will go too.
mud22 is offline
Old August 19th, 2012, 09:53 PM   #2
Doc
Doc's Avatar
Think I want these..
Doc is offline
Old August 19th, 2012, 09:55 PM   #3
Doc
Doc's Avatar
Was Dana 60 front high or low pinion? (Chevy/dodge or ford...)
Doc is offline
Old August 20th, 2012, 09:55 AM   #4
mud22
mud22's Avatar
Sale pending.
mud22 is offline
Old August 26th, 2012, 05:14 PM   #5
mud22
mud22's Avatar
Sold
mud22 is offline
Page generated in 0.16105 seconds with 38 queries
